jabr1319
Howdy all,
New owner of a G1900s with 1700 hours on it. 48" deck. I've only used it for a month (so roughly 4 times total) and it seemingly runs fine. Also new to these forums and I have to say I'm very impressed with the knowledge of this community. You've already helped me replace my pto belts.
The only issue I've come across so far is that I can make the machine stall if I make a sharp left turn. Basically the way my yard is laid out, I can make sharp left or right turns in my driveway to get ready for the next row to cut. When making 'zero-point' left turns, the engine will start sputtering. Sometimes I can give it a little gas and recover, sometimes not. This doesn't happen 100% of the time, but enough to be annoying. Tractor always starts right back up as if nothing happened. If I widen my turn everything works fine and she hums along happy as can be. Sharp right turns work perfectly.
I'm stumped. I don't see how turning would cause a stall. I can recreate with or without the mower deck engaged. Any insight would be greatly appreciated.
Thanks,
Josh
Thanks,
Josh
