Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    13
    holmes n.y.
    kubota bx25
    Default grapple bx25
    grapple for my bx25, any suggestions or ideas ,1 that is easy to install
    this is all new me
  2. #2
    Elite Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    4,785
    Somerset, Ky
    currently own F3080 F3080 B2620 FEL/BH RTV1140
    Default Re: grapple bx25
    Your in the Lawn and Garden forum. You'll get more response in the Kubota tractor owners forum here:Kubota Owning/Operating
    2012 B2620 FEL BH, 2010 F3080 4WD 72" Rear Discharge Deck, 2012 F3080 4WD 72" side discharge deck, 2010/2009 RTV1140CPX , RatchetRake, Forks, ...DEARBORN 2 BOTTOM PLOW 12" ?? FOR SALE $425).... Drawbar and Horse Drawn disk 11 Dodge Ram1500, 13 Ford Flex. 2009 Subaru Impreza Sport
  3. #3
    New Member
    Join Date
    Mar 2012
    Posts
    5
    Newfoundland
    Kubota
    You could always bolt on a thumb and use the hoe bucket & thumb as a grapple type arrangement if it would work for you. I got my thumb from Bro-Tek.
  4. #4
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    1,824
    Connecticut
    Kubota BX25
    There are a few products out there to add one to your BX but not cheap, or you can buy a bolt on thumb and like Garyoc posted above and then fabricate a mount for it on your FEL, then figure out how to add a third hydraulic circuit to your FEL to control it. Do a search in the attachments forum for "grappleomatic". Member Artisan posted a very comprehensive thread on how he added one to his BX25 and I think there's links to other products/options in that thread.
    Chris
    2 acres and a mule, er, Kubota BX25, and too many other toys,er, tools to list.
  5. #5
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    4,621
    Lancaster County, PA
    adding a grapple to a subcompact is not a good idea. After its all done, you maybe able to lift 200-250lbs of stuff. Its just not a good idea.
  6. #6
    Gold Member gtrippleb's Avatar
    Join Date
    Aug 2009
    Posts
    314
    Central NC
    CCY Sc2400 TL
    The thing with a grapple on a sub compact is knowing your limitation. For lifting brush you would probably be ok, but like MessickFarmEqu said, you're only going to be able to lift 200-250 .lbs. So you might have some problems if you are going to lift cut logs.
    That being said, I still want one on my Sc2400. I made some brush forks for my Sc2400 which work good, but I'd still like the capability of a full grapple.
    The weight of the bucket for the Sc2400 is 130 .lbs. The weight of the smallest 38" grapple from WRLong, is 280 .lbs. Bolt on is 143 .lbs
    RBG
    CCY Sc2400
    Woods PHD35
    Very Old 60" BB
    Harbor Freight QH
    EF115 Flail Mower
    BX42s Chipper
    County Line Carry-All
    County Line (Tarter Gate) 48" Tiller
    Homemade 60" Dethatcher
Similar Threads
  1. BX25 Grapple
    By Yooperman in forum Kubota Owning/Operating
    Last Post: 03-09-2012, 05:29 PM
  2. Replies: 15
    Last Post: 02-18-2012, 11:31 PM
  3. BX25 FEL Grapple
    By Artisan in forum Kubota Owning/Operating
    Last Post: 01-01-2012, 03:43 PM
  4. Comparison 2010 bx25 vs 2011 bx25
    By old fool in forum Kubota Buying/Pricing
    Last Post: 06-30-2011, 10:52 AM
  5. Grapple Kubota BX25 Grapple
    By p38 in forum Attachments
    Last Post: 07-02-2009, 01:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
