PHILIP8N
so I'm using toe/toe instead of heel/toe and it works fine.
I do have a question for GR2120 owners; When you turn the key part way, do ALL the warning lights go on to indicate they are working? On mine, the "overheat" warning light doesn't show and I'm concerned it might not be working.
is about 4 or 5 inches higher
an acre and a half the grass was 2 - 3 feet high in spots. The plan is that if this tractor works well for all my cutting, I'll be selling the RFM off of the larger tractor and use that one only for dirt and snow.
I was a bit taken aback by the manual requiring a five minute warm-up of the engine before using the tractor. I thought that was something that had pretty much been eliminated by the newer hydro drives. I also got a kick out of the manual stating the following: If you drink antifreeze, vomit immediately ;-)
I use the toe/toe as well, just what I am used to.
When I turn key to 1st 'run' position, only by battery and oil pressure lights come on. The high temp and glow plug do not illuminate.
I too was suprised how much higher the GR is to step up on compared to my old Deere LX188.
An acre and a half of 2-3 foot grass seems a little much to me for a GR unit. I would stick with bush hog and tractor if it was me.
In warm weather, say 65F+, I do not warm up that long, only a couple minutes.
Philip
