Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member
    Join Date
    Jan 2013
    Posts
    27
    Mifflinburg, Pa
    Kubota B2920 MMM, FEL, BX1860 mmm, Fel
    Default Mulcher for a BX1860 54" deck any advice?
    I checked on a Mulch kit for this BX1860 I will be getting. I spend a lot of time in the fall with leaves. A dealer along time ago talked me into a mulcher for my GR because I told him I spend equal amounts of time collecting leaves as I do cutting grass. I also found myself running around to blow the leaves off my yard. With the mulcher it grinds them up more.
    Will a mulcher on the BX 54" deck work as well as one did on my GR 48" Deck?
    Deck RCK54-23BX
    Baffle kit - Part Number: 70000-70467
    Blades - Part Number: 70000-25019 NEED THREE
    Thanks to Jordan at Messicks
  2. #2
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Default Re: Mulcher for a BX1860 54" deck any advice?
    yeah... dont bother with it
  3. #3
    New Member
    Join Date
    Jun 2012
    Posts
    13
    East Aurora, NY
    Kubota GR2120
    I have a GR2120 with the 54" deck on it and I installed the mulching kit on it last year. It really works great, so good that I didn't remove it for even the heavy mowing in the spring. I did get a set of gator blades for it and am very happy with them. The 21hp diesel on the GR2120 handles the load very well. I would think that the 1860 should be close.
  4. #4
    Join Date
    Oct 2010
    Posts
    595
    New Holland TC 29D
    Default
    Instead of buying a mulching kit for my BX, I made steel plate that covers the side opening of the mower deck. This prevents all the grass and leaves from being blown out the side and mulches them very well.
    TC-29DA
    BX-1500
  5. #5
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    I had the kit on my BX and it sucked. Clogged up. It also cut the lift way back so the cut suffered big time. Best thing I did was remove it.
    I built a OCDC http://www.tractorbynet.com/forums/K...locker-bx.html and run Oregon Gator Mulcher blades, and that improved the performance. I usually run with the chute open, unless im near the house or somewheres else I want to control discharge
    With the GM blades it cuts every bit as fine as the mulch kit and has more lift so the cut is more even.
  6. #6
    Join Date
    Oct 2010
    Posts
    595
    New Holland TC 29D
    Mulcher for a BX1860 54" deck any advice?-008-jpgMulcher for a BX1860 54" deck any advice?-009-jpgMulcher for a BX1860 54" deck any advice?-007-jpgHere is the chute blocker that I made, it's not as fancy as Scooby's but it works great for mulching leaves.
    It's just a piece of heavy sheet metal with a piece of angle iron welded to the top. I then welded two short bolts to the angle iron. Those bolts act as locating pins for the two holes the are already on the top of the deck.
    The blocking plate just drops down into the those two holes and the plastic deflector, which is spring loaded, holds it in place.
    TC-29DA
    BX-1500
  7. #7
    Join Date
    Oct 2010
    Posts
    595
    New Holland TC 29D
    Quote Originally Posted by V1Rotate View Post
    Oops, when I said "plastic deflector" I meant metal deflector. ( I was thinking of another mower).
    TC-29DA
    BX-1500
  8. #8
    Platinum Member kcender's Avatar
    Join Date
    Mar 2010
    Posts
    870
    Nova Scotia
    GR2120 B2650 Cab
    I like that,simple but effective.I will probably make one for my GR2120 to mulch up the leaves in the fall.I had the mulching kit for the 54 inch fine cut deck on my previous BX2360 but never used it as it was a PITA to install and remove.It is basically the same thing for the GR.I really only mulch to get rid of leaves in the fall so your blocker would be ideal for me,easy to install and remove.
  9. #9
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Interesting idea.
    I usually am not trying to mulch. I gave up! But I use my chute blocker to control where the discharge goes, like not into flowerbeds or throwing debris at vehicles or on driveways etc. so mine needs to be enabled and disabled on the fly from the operators seat.
    For someone who is only mulching leaves etc. a couple times a year, yours would work great.
  10. #10
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I saw this on youtube the other night.
Similar Threads
  1. Mowing BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade?
    By wrooster in forum Kubota Owning/Operating
    Last Post: 06-17-2013, 11:50 AM
  2. 89 316 50" deck blues - could use some help and advice
    By rtpguy in forum John Deere Lawn & Garden
    Last Post: 05-27-2012, 11:23 PM
  3. New BX1860 Deck confusion
    By MNoble in forum Kubota Buying/Pricing
    Last Post: 06-24-2011, 09:48 PM
  4. BX1860 54" deck and Gator blades
    By mow4fun in forum Kubota Owning/Operating
    Last Post: 04-12-2011, 10:59 PM
  5. Kubots ZD 326 w/ 60" deck-Free Mulcher !!
    By Cleev1 in forum Kubota Lawn & Garden
    Last Post: 10-30-2010, 07:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
