Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    22
    boston, ma
    g1900s
    Default G2001 plow for G1900s tractor - mounting questions
    I just picked up the plow and sub-frame (and free tire chains, sweet). From the looks of it, I have all parts. I'm wondering how it is designed to attached to the hydraulic lifts that the mower deck uses?
    I'm in the ballpark as far as hole locations, but the lifts on the tractor have a small plate welded on to them and I'm having a hard time visualizing how the plow connects. Can anyone take a picture of their assembled plow for me? I have the breakout image of the plow and can see i have all the proper parts, but I'm just not putting it all together...
    Here's the plow breakout image for reference. Part 13 (small rectangular plate) is what attaches to the tractor with a pin.
    G2001 plow for G1900s tractor - mounting questions-g2001-plow-parts-diagram-png
    Thanks,
    Josh
  2. #2
    Super Star Member
    Join Date
    Mar 2008
    Posts
    13,281
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: G2001 plow for G1900s tractor - mounting questions
    Part 13 should attach to the rear deck lift points.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    22
    boston, ma
    g1900s
    Right. The holes line up fairly close, I just cant seem to figure out how to properly connect them together. The rear deck lifts have a small plate welded to them that makes the connection not sit flush...apologies for the poor description. The deck lift connection area are in the shape of an upside down T. To connect part 13 would create a triangle shape... I'm guessing with a little more attention to it I can figure out how to connect them flush so it maintains the T shape.
  4. #4
    New Member
    Join Date
    May 2012
    Posts
    22
    boston, ma
    g1900s
    Here's a photo of the connections. I'm thinking maybe just put a couple washers in between the hydraulic lifts and the steel plate (part 13) so they are reasonably flush when i tighten the bolt. Any other suggestions? A day off tomorrow and 2 days until snow...i got this
    G2001 plow for G1900s tractor - mounting questions-plow-subframe-connection-hydraulic-lift
  5. #5
    Super Star Member
    Join Date
    Mar 2008
    Posts
    13,281
    Quote Originally Posted by jabr1319 View Post
    Assuming that part 13 is the one that you are holding in your hand and the bolt goes through the hole in the orange lift arm, I would say that you are on the right track.
    Is there also a lip on the inside of the lift arm?
    Aaron Z
  6. #6
    New Member
    Join Date
    May 2012
    Posts
    22
    boston, ma
    g1900s
    Quote Originally Posted by aczlan View Post
    Aaron Z
    Yes, same size lip on both sides. part 13 = the piece I'm holding. Seems like a strange setup, but if washers solve my problem I'm fine with that.
Similar Threads
  1. Grading Kubota G2001 Blade
    By DLKubota in forum Kubota Owning/Operating
    Last Post: 03-15-2014, 04:04 PM
  2. G1900s 48" mower deck belt replacement questions
    By jabr1319 in forum Kubota Lawn & Garden
    Last Post: 06-28-2013, 07:14 PM
  3. Mounting snow plow on GR2100
    By mpt1123 in forum Kubota Lawn & Garden
    Last Post: 10-08-2009, 06:21 PM
  4. G1900S rear PTO questions
    By txcactusdude in forum Kubota Owning/Operating
    Last Post: 05-07-2008, 04:47 PM
  5. Grading Kubota G2001 Blade
    By DLKubota in forum Owning/Operating
    Last Post: 01-06-2005, 01:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2016 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
