Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Platinum Member kcender's Avatar
    Join Date
    Mar 2010
    Posts
    864
    Nova Scotia
    GR2120 B2650 Cab
    Default Re: GR2120 creeping
    Quote Originally Posted by whitetiger View Post
    Neutral adjustment is done with an eccentric bushing just inside of the left rear tire. It has a 12 or 13 mm head bolt that you loosen and a slot that you insert a large screwdriver into to turn slightly. Before you attempt to adjust neutral jack up and block drive wheels off the ground, front axle also on powered front axle models. All G and F series use this method. With unit running adjust until wheels do not turn in neutral, stroke pedal back and forth to double check.
    The eccentric on an F series is right behind the battery on right hand side.
    I know this thread is a bit old but I finally got around to trying this.Ever since my GR was new it would creep a little bit when letting off reverse.It never really bothered me but I thought I would look into this adjustment.It wasn't a big deal to do and now the tractor stops perfectly when letting off the pedal in either direction.The hardest part was getting all wheels off the ground at once and that wasn't really a big deal.I wouldn't have known about this if it was not for this thread.That is the great thing about TBN,all the knowledge that is available.
  2. #12
    Join Date
    Jan 2001
    Posts
    161
    New Brunswick, Canada
    L5460 Kubota
    Does anyone have a pic of the the location of this bushing, mine has a slight creep now also.
  3. #13
    Join Date
    Jan 2001
    Posts
    161
    L5460 Kubota
    Just found the page in the service manual. Should have looked before posting.
  4. #14
    Gold Member Pete6114's Avatar
    Join Date
    Dec 2000
    Posts
    317
    SW Ontario, Canada
    F2690 GR2120(Sold) L3240(sold) B1700(sold)
    Quote Originally Posted by sandalwood View Post
    Great!. Now if you'd post a picture of the location of this bushing on here, folks without a service manual (me) will be thankful!
  5. #15
    Join Date
    Jan 2001
    Posts
    161
    L5460 Kubota
    Here you go.
    Attached Thumbnails Attached Thumbnails GR2120 creeping-hst-jpg
  6. #16
    Join Date
    Dec 2000
    Posts
    317
    SW Ontario, Canada
    Here you go.
    Thanks!
Similar Threads
  1. GR2120 48 vs 54 deck
    By Garth91 in forum Kubota Lawn & Garden
    Last Post: 02-24-2014, 09:08 PM
  2. GR2120
    By jbgood in forum Kubota Lawn & Garden
    Last Post: 05-24-2012, 10:04 PM
  3. GR2120 Questions
    By jbgood in forum Kubota Owning/Operating
    Last Post: 02-14-2012, 12:15 PM
  4. The Kubota GR2120?
    By handirifle in forum Owning/Operating
    Last Post: 06-18-2011, 08:39 AM
  5. GR2120/GR2020
    By jas67 in forum Kubota Lawn & Garden
    Last Post: 05-22-2011, 08:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
