Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Elite Member Sigarms's Avatar
    Join Date
    Feb 2005
    Posts
    4,622
    Mid north west in the state of N.C
    F3080
    Default F mower squeaking?
    I probably put 3-5 hours a week on my F3080. Some of it's pretty rough ground, rarely ever mow in the higher speed range (pretty much stays on the "turtle").
    I swear I hear the back end squealing sometimes and I'm not sure if it's just me or a potential problem.
    I grease the machine on all of it's grease points religiously, never going past 5 hours without doing the whole machine.
    Looking in the manual, there are only two points that need oiling, the seat adjuster and the throttle cable.
    Am I missing something??
    I almost feel like just taking some oil to all the metal contact points (joints) and be done with it.
    Just wondering if it's just me or not.
    Just because you can't do everything, doesn't mean that you have to chose to do nothing.
  2. #2
    Gold Member Pete6114's Avatar
    Join Date
    Dec 2000
    Posts
    335
    SW Ontario, Canada
    F2690 GR2120(Sold) L3240(sold) B1700(sold)
    Default Re: F mower squeaking?
    I don't want to hear this! Just bought a F-Series mower....
    What i noticed when i test drove it at the dealer is, 1) the engine cover latch seems "loose" and needs adjustment. 2) the black plastic fender thingys on both sides squeak a bit till the RPM is increased.
    In your case, i'd take a good look at the engine cover for movement/hinges, asuming that that noise is behind you and not the rear of the deck...
  3. #3
    New Member
    Join Date
    Jun 2015
    Posts
    16
    Cantley, QC, Canada
    Kubota L3710, F3060
    Don't want to hear this either, I'm about to pull the trigger on an F2690 with RD 60" mower and snow blower.
  4. #4
    Join Date
    Dec 2009
    Posts
    166
    Ottawa Ontario
    Cub 982, B7800, F3680
    Quote Originally Posted by Moosetracker View Post
    Hello Gents,
    As with most equipment, there are plenty of metal to metal contact points on the mower deck and the lift arm systems on the F tractors. I find that mine gets a few squeaks especially after I power wash it, but as recommended in the operators manual, its a good idea to put some 50 or 75 weight gear oil in a squirt can (or spray can of chain lube oil works best) and lube up as many of the connection points as you can. Squeaks are a fact of life unfortunately but they can be almost eliminated with an oil can... my 2 cents' worth.
    You will enjoy your new investments as you become familiar with the machines, I feel the F series is truly a superior machine...
    Dan
  5. #5
    Join Date
    Feb 2005
    Posts
    4,622
    F3080
    Dan
    Thanks for the reply.
    When you mention operators manual, are you refering to the deck or mower manual, and what area in the manual (page number)? I ask only because I had to of miss it.
    Common sense tells me to lube, and although I feel like an idiot for asking such a simple question, because I didn't see anything mentioned in writing, why I felt compelled to ask.
  6. #6
    Join Date
    Dec 2000
    Posts
    335
    SW Ontario, Canada
    When you said "back end squealing", i assume it's in the back of the machine (behind you), but as we all know, sound travels.
    does it only squeal while driving or does it do it when stationary too? does it squeal when turning or driving straight?
    You need to figure out when it makes noise.
    Check the engine cover,
    Check the wheel bearings
  7. #7
    Join Date
    Jan 2001
    Posts
    161
    New Brunswick, Canada
    L5460 Kubota
    Quote Originally Posted by Sigarms View Post
    Dan
    Not sure if this is what you were looking for?
    Attached Thumbnails Attached Thumbnails F mower squeaking?-lub1-jpg   F mower squeaking?-lub2-jpg
  8. #8
    Join Date
    Feb 2005
    Posts
    4,622
    F3080
    Quote Originally Posted by sandalwood View Post
    No, I have that.
    I don't see anything in either manual about general "oiling and lubricating" metal parts (on the mower) other than mentioned per my first post (seat adjuster and throttle cable).
  9. #9
    Join Date
    Jan 2007
    Posts
    1,406
    Creal Springs, IL
    Kubota M7040, F3680, Mule Pro Fxt
    Being hard of hearing does have it's advantages. What's a squeak?
  10. #10
    Join Date
    Dec 2000
    Posts
    335
    SW Ontario, Canada
    Quote Originally Posted by jcummins View Post
    Ever hear the sound your walled makes when you open it?
Similar Threads
  1. Kioti NX - Cab door squeaking
    By DeanFM in forum Kioti Owning/Operating
    Last Post: 05-12-2015, 08:10 AM
  2. JD6105R Squeaking Noise
    By sleddog in forum John Deere Ag Tractors
    Last Post: 12-16-2013, 07:39 AM
  3. Gator HPX squeaking
    By sargex595 in forum ATVs & Utility Vehicles
    Last Post: 04-18-2010, 07:41 PM
  4. B7800 loud squeaking when cold
    By SuperDave in forum Kubota Owning/Operating
    Last Post: 04-03-2010, 12:46 PM
  5. TN 75D steeing squeaking
    By MikeF in forum New Holland Owning/Operating
    Last Post: 05-31-2005, 06:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
