Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    Join Date
    Sep 2001
    Posts
    17
    Harnett County, North Carolina
    2k 2710, 1950 Ford 8N
    Default Removing Trees??
    Anybody have a tried and true method? I have a 2710 with a FEL. I usually use some combination of digging,pushing,pulling to get trees up. Of course, the amount of each depends on the tree type :~> Is there a BETTER way? So far, mine has been trial and error.
    Thanks,
    greg
  2. #2
    Join Date
    Jul 2001
    Posts
    170
    East/Central Missouri
    Kubota B7500HST (Kobi)
    Default Re: Removing Trees??
    Greg,
    Personally, I like to use a chain saw [img]/w3tcompact/icons/wink.gif[/img]
    Seriously though, I know you'll get alot of good suggestions and techniques from the guys. My one and only "bit" of advice would be to get a toothbar for your FEL if you don't already have one. Makes digging and popping small trees a whole lot easier.
  3. #3
    Join Date
    Mar 2001
    Posts
    69
    Upper Peninsula of MI.
    Kubota L4610HST
    I have good sandy, loam soil, and shallow-root trees, so they topple pretty easy, with the 4610 and FEL. I've pushed over spruce/fir/tamerack in the 10-12" range-30' high, and pines in the 8" range.
    I start high on the tree and push, with minimal to no digging. Eventually the tree will fall over, and I lift up the root ball, sometimes from side to side, and carry the tree backwards with the toothbar. I then approach the tree from the side, and carry to a pile.
    On a couple of the bigger trees, I first cut the root ball off, throwing it on a pile, then I wrapped a chain around the trunk of the tree, and dragged the tree out into the clearing to approach from the side and carry.
    One thing to watch with this method though, you don't realize how heavy those trees are, and how strong the branches can be. I have a couple of dents on the grill of my tractor, even dented the push bar in the front when a couple of stiff roots caught me!
    Have fun and watch your balance!
    Jeff...U.P. of Michigan.
  4. #4
    Join Date
    Oct 2001
    Posts
    83
    South Dakota
    2001 New Holland TC45D, 1953 JD 40 crawler, 1949 JD A, 1993 Lahman skidsteer
    If you have some extra money to spend on attachments a tree shear would be nice ($2500 to $7000 depending on which size). There are a couple of guys in the area that have these on skidsteers and they work great. They hire out for about $55/hr.
    http://www.mightyaxe.com/
    <A target="_blank" HREF=http://www.midlandindustrialgroup.com/aamain.html>http://www.midlandindustrialgroup.com/aamain.html</A>
  5. #5
    Gold Member
    Join Date
    Apr 2000
    Posts
    444
    Central Arkansas
    Kubota /L2650/ LA450/B4690 -- John Deere 450 Dozer
    Jeff, I had a treepuller made to fit on the 3pt for about $140 it works great for 2-4 inch trees, will handle some 6 incher. It is the fast and easy way to take out this size trees. You can find it in a earlier thread.
  6. #6
    Join Date
    May 2001
    Posts
    670
    Ontario, NY
    JD 790 (2001)
    Greg,
    Here's a shot of a tree I transplanted two weeks ago. This was pure FEL action. I now have a toothbar and am dying to try it out!
    Buck
    Attached Images Attached Images
  7. #7
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,303
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    I have had pretty good luck leaving 3 to 4 feet of stump from the base,than I can loosen the stump w/the fel etc..
    Something in the old days when farmers used oxens to remove stumps.
  8. #8
    Join Date
    Aug 2001
    Posts
    990
    Winchester, New Hampshire
    Kubota L3000
    Depends on how big the trees are. On the larger trees I dig around the base and sever the larger roots below ground. They can some times be pulled up and out easier one at a time.
    I have a 3PH mounted winch so I put 16' ladder against the tree, climb to the top of the ladder and put a chain around the tree. Then I get at least 100 feet from the tree with the tractor and pull the tree over. Most of the time it works. I have found spring time is the best time to do this as the ground is softer.
    I used to try to push them over with the FEL but found that pulling them over was easier on the tractor. Just becareful when you push that the upper branches don't break off and fall on you if there are other tress near by.
    Randy
  9. #9
    Join Date
    Feb 2002
    Posts
    129
    Missouri
    BX2200 / FORD JUBILEE
    Jag, I went back through the thread you mentioned and that looks like a very handy attachment. My question is about operation, do you just back in to get a good bite then use the three point to lift, or do you use the momentum of the moving tractor to pull the sapling. I ask this because I have a BX2200 with not a lot of lift capacity. Do you think it would be worth my time to build one for such a little tractor?
    Thanks ,
  10. #10
    Gold Member
    Join Date
    Apr 2000
    Posts
    444
    Central Arkansas
    Greg, one thing I forgot to say is.... NO TWO TREES ARE ALIKE.. Be careful, trees are dangerous. One can snap off at the base, one can snap off up high when you push on it.. If you are pushing a tree that has a dead spot in it or a large limb up high that is dead, when it goes guess which way it is going to come dowm. I have had a bunch of construction guys tell me that clearing tress is one of the most dangerous thing they have to do... If you need proof check on the insurance a tree cutting company has to pay....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
