istalli p/s on b7100
   / istalli p/s on b7100 #1
robbieo11
93 B7100
i have had it with the armstrong my right arm can barely move I will install p/s on the bota I amlookng for a danfoss steering valve anda cylinder so i can ti into the hydro for p/s
   / istalli p/s on b7100 #2
Yup that's the only draw back on those little mules PS :(...also the joy stick after many hours of use.
I'll be very interested in update how you make out.
found pump have to remove steering gearbox all together and fab a mountto go to "dash" for support and te cover for hydro filter
   / istalli p/s on b7100 #4
I'm not sure if this site might help you with your project. They sell power steering kits for older full sized tractors but looking at some of the kits and reading the FAQ's might point you in the right directions.
Jackson Power Steering :: FAQ
Cheers, Erik
   / istalli p/s on b7100 #5
robbieo11 said:
i have had it with the armstrong my right arm can barely move I will install p/s on the bota ...
Robbie, you hit the nail squarely on the head. The lack of PS on my 1995 B7100HST was the main reason for my moving to the BX series. I spent about a year looking for safe and ingenious ways to install PS on my B7100. I eventually came to realize that the cost of new parts was prohibitive, that a lot of work would be involved, and that the end result might not be completely satisfactory.
There is still a demand for the legendary B7100. If you consider its market value, and then add the cost of fabricating a proper PS for it, you will arrive at a final monetary value for that B7100. If you do the calculations, I think that you will find that you can actually buy another used Kubota with factory engineered PS for about the same price as the above final B7100 monetary value.
i paid 5600 for unit 3 years ago put 400 plus hours on it has loader and 60" mmm. parts total going to cost aroung $250 good ole ebay. unit has 1800 hrs on it now just done al fluid chages and grease. have to replace 1 hose on loader that is starting to "sepe". with power steering in good working order and installed to look lke factory. I would have to think long and hard to even consider an offer of $8500. for the little power house. As far as major components search for DANFOSS on ebay This is most expensive part. yes have to fab a colum nad hoses tractor supply carries hoses and they even got a 5" travel cylinder for $85 just time involved at that point and usingtorch plasma cutterand mig welder
Hi all I am going to install hydro/power steering on my b7100 and wanted everone to know ill be posting info on my experence with it.
I am removing the hole orginal steering and building backets or a danfoss ospm steering unit and cylinder to connect to existing hydro
   / istalli p/s on b7100 #8
Take lots of pics please! As another b7100 owner I am interested in how it goes :)
pwer steering is done though i have some tweking to do gotta make it ook pretty. i will be postiing pics soon
   / istalli p/s on b7100 #10
I patiently await....
But could you hurry please? :eek:
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
