DiezNutz
Toolguy, with all due respect...
Now let's suppose same dealer stuck with Kubota recommendations and as a result those same engines went hundreds if not a couple thousand hours longer. Why? By not being subjected to increased wear during the early hours of their service life when the thicker oil didn't get into those bearings and bushings quite as fast from cold starts. Guess we'll never know! It's similar to, "well if Bob hadn't smoked cigarettes for 20 years, he would've lived 10 years longer before that heart attack". Except direct cause-and-effect relationships between cigarettes and health problems are well-established, having been studied by legions of doctors and scientists. Dealers aren't busy looking for a pattern...again, because nobody's complaining, and if they did - well "prove it". Kubota has published their recommendations, but they don't have the resources to police them. The effects won't show up until LONG after the warranty is expired, so chances are they never know what the dealer uses.
Some common-knowledge facts:
In the "gearhead" circles I also run in, the conventional wisdom is if you're going to deviate from the recommendations when breaking in a new motor, you go a grade THINNER than normal or not at all.
Lastly, the question of all questions is:
Does KUBOTA manufacture, contract, distrubute, or sell 15W-40 oil?
OK. I'm spent.
That has no bearing here. Cummins endorses 15w-40 for your engine.Toolguy said:I use regular Mobil Delvac 15w-40 in my work truck's engine, a 5.9L Cummins.
Also has little bearing here (and isn't completely true, as I've bought other weights in non-so-exotic places).Toolguy said:Go to any place that sells Diesel oil and all you're going to find is 15w-40 regular or 5w-40 synthetic.
Would they? Bear with me for a second... let's suppose all they've ever used is 15w-40. And the average Kubota they sold needs an engine rebuild at X hours. Now X is probably a big number, like several thousand hours, so noone thinks it's strange or knows the difference... all seems perfectly reasonable. The customer probably doesn't bat an eye because "it's lasted so long", and the dealer is happy because it's keeping the service dept. earning. As far as anyone knows, yep, that's just how long they last (because it's only ever been done one way).Toolguy said:The Kubota dealers that recommend 15w-40 are not stupid. If it caused problems they would be the first to know.
I agree 100% with that. Using the "wrong" grade oil isn't going to directly cause engine failure, at least not any more than I can pinpoint whether a Big Mac I ate 10 years ago will give me cancer 10 years from now, nor would I worry about it. To "your engine will last a long time" I would like to add, "even longer if you use the correct service & grade oil". Seems like a simple preventative-maintenance thing to do. What good argument is there NOT to use what Kubota specifies? Saving a few pennies a quart? We all talk about things we can do to make these tractors last forever... so why give my Kubota a cigarette and take a chance on robbing some of its life?Toolguy said:Oil related engine failure is probably the last thing anyone needs to worry about. Just change it at regular intervals and your engine will last a long time.
- Internal engine wear is never more accelerated than during a cold-start and the moments that follow due to lack of available and complete lubrication.
- The first number in a multi-grade oil is the ever-important cold viscosity grade, or the equivalent weight of the oil when cold. It is directly proportional to how rapidly and completely the oil will flow to the bearing surfaces.
- The thicker the oil at cold, the higher the system oil pressure. Don't count on the pump to "force" the oil where it needs to go once the pressure relief opens. That oil will have to come up to a higher temperature to achieve the same viscosity/lubricity as the lighter grade. What's happening in the meantime?
OK. I'm spent.
