milkman
Elite Member
- Joined
- Sep 22, 2001
- Messages
- 3,629
- Tractor
- BX2200, BCS 735
Simple solution, set the park brake, put the hydro in low range and inch the tractor into position with the hydro pedal, works every time.
yup...milkman said:Simple solution, set the park brake, put the hydro in low range and inch the tractor into position with the hydro pedal, works every time.
OK. Assuming you have the FEL on (which you would if mounting BH), you can also drop it once you have the tractor in position. You can also "level up" the front of the tractor with it, which may help you align w/the implement.acohen100 said:Well on a few occasions I have had to back up into the BH for remounting on a slight grade - or at the edge of my shed with the front wheels hanging over the front lip andpulling the tractor forward. The tractor tends to want to roll forward while you are trying to feather the reverse and lock it in the correct position.
Botabill said:I think it make sense to have the brake on the right side as it forces the driver to take their foot off the power (gas/diesel) pedal if they need to press the brake. We are trained to do that when we learn to drive a car as a safety feature and in most cases for those of us who drive it is an automatic reaction when we need to brake in a hurry. It might be an advantage in some situations to have it on the left side but I can't think of a situation where I'd use it often. As one poster aready mentioned... with the Hydrostatic drive the power pedal is a brake itself and the 'brake' is usually only used for parking.
Exactly. Another reason it's on the right is the clutch is on the left (for the Kubotas that have them). Kubota isn't going to change the whole setup and what operators are used to, just because the clutch isn't there.Botabill said:I think it make sense to have the brake on the right side as it forces the driver to take their foot off the power (gas/diesel) pedal if they need to press the brake. We are trained to do that when we learn to drive a car as a safety feature and in most cases for those of us who drive it is an automatic reaction when we need to brake in a hurry.
acohen100 said:Ah well I found my answer. I like the FEL use idea. I can see locking the break and creeping in idea working too. That would be nice and easy. Thanks for the tips. I feel pretty retarded for not having thought of that.
