Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    May 2007
    Posts
    9
    Eaton Rapids, MI
    Kubota B7610
    Default 2630 Box blade size
    I did a search on box blade size and could not find anything about what size to use with a 2630. I will mostly be using it to leval my drive (which is lime stone and dirt) and for smoothing and levaling food plots.
    kubota recomends a 54" the dealer said 60", I looked at a 60 and "Damb" that thing is big! Wondering what size you guys use with the 2630.
  2. #2
    Member
    Join Date
    Jun 2006
    Posts
    48
    Ohio
    B2630
    Default Re: 2630 Box blade size
    I use a 60" rear blade with my 2630 without much problems. I don't if the box blade would be much differant.
  3. #3
    Elite Member jbrumberg's Avatar
    Join Date
    Jan 2006
    Posts
    2,675
    Western MA
    New Holland TC29DA, John Deere 455D
    Big Daddy M:
    Welcome to TBN ! I think your tractor could handle a 60" box blade for your stated uses. Your 3PH could lift a HD box blade. I would be concerned about the "balance" between an 1800+ pound tractor and a 500 HD pound box blade especially if you were going to be doing serious "dirt work" in heavy, rocky, obstructed soil due to lack of traction. Jay
    PS: Your tractor's tires are another important consideraton as to traction.
    NH TC29DA with 14LA and HD QA 60" bucket, weighted R-1's, FOPS, CCM M-160 (58") Tiller, Tebben MD 60" Rotary Cutter, Woods LR 108 (96") Landscape Rake, FEL cutting edge and tooth bar, Woods GB60 (60") Box Blade, Wallenstein BXM32
    1995 John Deere 455 Diesel with 48" mower, MC 519 Cart with PowerVac
  4. #4
    Veteran Member DiezNutz's Avatar
    Join Date
    May 2006
    Posts
    1,019
    Central MD
    Kubota B3030-HSD-F
    You could run a standard duty 60" BB around 500# with no trouble (e.g., Woods GB60 or similar). I think a heavy-duty BB would be too much weight and drag.
    I run a 72" RB without any problems. It does take more tractor to run a BB than a RB, but at 60" you should be fine.
    Kubota B3030-HSD w/R4s, LA403 60" FEL w/ATI TB, RCK60" MMM, Woods BH80-X 4pt Hoe w/24"+12" bkts & Thumb, Woods RB72" Blade w/shoes
  5. #5
    Join Date
    Jan 2006
    Posts
    2,675
    Western MA
    DiezNutz:
    I agree with you about the appropriateness of a medium duty box blade for a 2630. A 2630 has quite the 3PH lift capabilities ; not that I am sanctionning the use of a HD box blade for a 2630. Jay
  6. #6
    Join Date
    Jun 2006
    Posts
    75
    Middle Peninsula Virginia
    Kubota B7610 and JD LT155
    If you are just scrapping go with the 60" box blade. If you want to dig deep or move a box load of material go smaller. I scrapped off three inches of turf for a riding ring after using the scarfiers to break it up. FEL helps lots and keeps weight on the front.
    Mike
    B7610HSD-F W/LA352 FEL
    Land Pride BB1560 5' Box Scrapper
    Land Pride FDR1660 5' RFM
  7. #7
    New Member
    Join Date
    May 2007
    Posts
    9
    Eaton Rapids, MI
    Kubota B7610
    Thanks everyone! Most likely a stupid question but what is "BB" and "RB"? Also, should I go with the kubota scraper? Dealer quoted me $760.00 for a Woods GB60, the kubota would be about $900.00
  8. #8
    Veteran Member amigauser's Avatar
    Join Date
    Oct 2005
    Posts
    1,198
    Unionville, Connecticut USA
    Kubota B2601
    BB = "Box Blade"
    RB = "Rear Blade"
    You will also see:
    FEL = "Front End Loader"
    MMM = "Mid Mount Mower"
    RFM = "Rear Finish Mower"
    BH = "Brush Hog"
    Etc.
  9. #9
    Join Date
    May 2006
    Posts
    1,019
    Central MD
    Kubota B3030-HSD-F
    Quote Originally Posted by jbrumberg
    Right. You wouldn't want someone to confuse the 3PH lift capacity (lift only)vs. the ability of the tractor to carry, safely and effectively operate a rear implement. That ratio is approx 3:1.
  10. #10
    Join Date
    May 2006
    Posts
    1,019
    Central MD
    Kubota B3030-HSD-F
    Quote Originally Posted by amigauser
    BB = "Box Blade"
    RB = "Rear Blade"
    You will also see:
    BH = "Brush Hog"
    Etc.
    Correct. However, "BH = BackHoe" trumps "BH = Bush Hog" every time
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
