Extra Hydraulics for BX2350???
   / Extra Hydraulics for BX2350??? #1
Musclford
Central, IL - USA
BX2350
I'd like to add another cylinder to my BX... Either for the 3pt and / or a cylinder for turning my plow when mounted to my front bucket...
Anyone done this?
Thanks
Phil
   / Extra Hydraulics for BX2350??? #2
The 2350 has a standard 4 position valve for the FEL, shich should be just fine for a plow angling cylinder...I believe Kubota sells just such an animal.
As far as the 3point, you should be able to plumb in just like the BX24...Just a matter of parts.
   / Extra Hydraulics for BX2350??? #3
I just spoke to my dealer about adding hydraulic remote for top link to my BX2350. Pricing on BX was surprisingly reasonable:
REAR REMOTE HYDRAULICS
BX7322 Rear Remote Hydraulic Valve Kit $ 284.00
BX Series Tractors 3-position
standard type dual acting.
Requires Hose Kit BX7232, BX7324, or BX7325
BX7323 Hose Kit for all $ 174.00
BX Series equipped with LA181, LA181FL-2,
LA211, or LA211FL-2 Loader. (Not compatible
with LA211FL-1 Loader.)
BX7324 Hose Kit for all $ 174.00
BX Series not equipped with loader
BX7325 Hose Kit for all $ 174.00
BX Series with LA181FL-1 and LA211FL-1 Loaders
I was told that the control for this remote would be in the open location on the fender so it would be a very clean installation. I have looked at some of the multi rear remotes the local guys have done on TBN but they are too involved for me and a BX. While a hyd top link would be very handy with a landscape rake and/or box blade, I really can't see the need for a tip and tilt conversion for my limited needs. I told my dealer I would have this done with my 50hr service. Next year so I'll keep in touch on this as I have never seen a posting on the BX hydro upgrade here?
   / Extra Hydraulics for BX2350??? #4
There is my set-up!
$310 CAD, that includes every things, valve, fittings.
   / Extra Hydraulics for BX2350??? #5
skippy957 said:
There is my set-up!
Looks nice but could you expand a little on this?
Did you build this out of parts or is it a kit or Kobota factory?
Where are the control levers?
   / Extra Hydraulics for BX2350??? #6
This is home made. I got a valoil valve from my hydraulic dealer near by and plumb the hydraulic tubes my self. The controls are oriented inside beside the seat.
It is cheep and works great. Here in Canada my Kubots dealer was too expensive around $500 for a kit.
You must use a power-by-on set-up in line with the FEL.
   / Extra Hydraulics for BX2350??? #7
Hi. The installation looks great! Same thoughts as I have! Is there any hydralic diagram for the BX24/2350? Would help alot!
/Sam
   / Extra Hydraulics for BX2350??? #8
skippy957 said:
This is home made.
You did a fantastic job and it is apparent you have created a snow killer Kubota.
See this is where the wheels start to come off the cart for me. I have so little hydraulic knowledge that if I tried this my dealer would get the wind fall then I paid him to straighten my work out.:(
I would really like to see or hear from someone with Kubota factor system for the single remote. At <$400 including labor this looks like a reasonable program for the hydraulically impaired.
   / Extra Hydraulics for BX2350??? #9
There are the 2 hydraulic schema that i fund, it will help, i hope.
  • hydraulic.pdf
  • hydraulic2.pdf
   / Extra Hydraulics for BX2350??? #10
Was that in English? :eek: Now I know I'm leaving this to the experts. :D
Year: 2005 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2005 Make...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Husqvarna 440 Chainsaw (A51573)
Husqvarna 440...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
