canoetrpr
- Joined
- Aug 7, 2005
- Messages
- 2,396
- Location
- Ontario, Canada
- Tractor
- Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Chances are I'll get my remotes going much before I have the $ to get a backhoe but I can't figure out how the backhoe would plug in.
My understanding is that if I was just installing a BH I would need a hose from the power beyond port of the loader valve to come back to the rear of the tractor to power the BH (instead of going straight to the hydraulic block) and then have the return from the BH going into the hydraulic block where the hose from the PB of the loader used to go.
When the BH is not being used the hoses at the back need to be connected together so that the fluid just flows through.
Now how does one set this up so that you can also have remotes when you are not using the BH? I imagine it involves installing some manner of quick disconnect to pull the input hose out of the remote valve and the hose from the PB of the remote valve for the output of the BH.
If you've got an installation with remotes AND a BH, I'd sure appreciate knowing how it was plumbed so that I could do it right when I do my remotes.
