Kubota RPM PTO (change 540 to 828 rpm)
   / Kubota RPM PTO (change 540 to 828 rpm) #1
lou41
Hi'
I've recently bought a Kubota tractor 4x4 L-235 3 cyl diesel (used 1985),
and I don't know how change the PTO speed. the PTO rpm is 540 (motor rpm
at 2600-2700) but this tractor model had 2 speeds PTO (540 and 828), and I don't have the owner manuel, and Im not able to change, I dont know how.. where,,, somebody can help me..? (this model is continous PTO with double-clutch)
Thanks;
Lou email: :rolleyes: mdjh@sympatico.ca
   / Kubota RPM PTO (change 540 to 828 rpm) #2
There should be a lever on the left side of the transmission - with L-N-H markings (low-neutral-high). On these early L's the lever is welded to the socket just outside the transmission case - the weld can break off and then it looks like there's no shifter - if that has happened, use vise grips.;)
   / Kubota RPM PTO (change 540 to 828 rpm) #3
Sounds right, I think my BIL's L175 is also on the left, a little more under the seat if I recall. Kind of a skinny lever.
Rob
