Oil & Fuel 50hr front axle oil??
   / 50hr front axle oil?? #11
For my L3400HST 50 hour service:
Change:
Engine oil
Transmission fluid
Front axle case oil
Replace:
Engine oil filter
Hydraulic oil filter
HST oil filter
Adjust:
Clutch
I bought the super UDT oil and filters for $220.
   / 50hr front axle oil?? #12
Interesting that the GL does not call for a front axle oil change at 50. The L3400 calls for all fluids and filters to be changed at 50.
   / 50hr front axle oil?? #13
Even my M4900 calls for the front axle oil to be changed at the first 50 hrs. Then at 600 hrs intervals, I probably will not wait that long. I use SUDT. The temp this morning when I went to plow was 7 degrees F. Yike!!
   / 50hr front axle oil?? #14
I know this is a small thing, but...
It would be nice if Kubota would standardize the maintenance schedules for their tractors. It simply leads to lots of confusion for owners who are doing their own maintenance. Surely the various models are not built so differently that they require such different maintenance schedules.
For example, is the L3400 4WD front axle so different from the L3240 4WD front axle that the L3400 requires the first oil change at 50 hrs and the L3240 not until 400 hrs ?
Note the "generic" maintenance schedule on the Kubota site is based on a 300 hour cycle while the Grand L 40's cycle is based on a 400 hour cycle.
Talon Dancer
   / 50hr front axle oil?? #15
Dutchman56,
You did the smart thing. I am assuming the UDT is the premium? In the USA it's called SUDT and is a multiviscosity 5w30 where the standard UDT is straight 30w.
The people that use 80w90 are mostly southern USA. That is fine there, in fact may even be better. But here in the chilly areas of the world, the SUDT works better in the cold.
I think there is also a hydraulic strainer (metal mesh screen) that needs to be cleaned of any mfg residues.
jb
   / 50hr front axle oil?? #16
I went through the same questions.
In Canada: there is only one UDT ... it is the premium stuff for weather reasons.
In the gear box and front axle, I use the best Synthetic gear oil available (the capacity is not great and it will not cost you a fortune.
For the tranny, I use the Kubota UDT.
I hope this helps?
Eric
   / 50hr front axle oil?? #17
Dutchman,
I don't know about your fluid question, but that's what I call a snowblower!!
   / 50hr front axle oil?? #18
The Kubota manuals really aren't causing the confusion. Its in threads like this that cause the confusion. If the manual for his tractor says to change it at 50, that's when he should change it, regardless of what the manual for someone's BX or M calls for. I'm not fussing, I'm just saying, for any given model, simply follow the recommendations for that model.
I put SUDT back in the front end of my L4400 primarily just for simplicity and due to the fact that after filling the tranny there would be enough left over for the front. It gets very hot here and winters are mild so gear oil would be just as good. But, my impression is that the front ends systems on these machines are pretty low speed environments and the lubrication demands not all that high.
The confusing thing was that both UDT and gear oil was in fluids listing in manual. but that is cleared up now. Will go up to camp after Christmas and spend a week there playing in the snow. Blower works great though am going through chains. I am discussing in another thread. But manual is clear all oils and filters including front end at 50 then at 400 hr intervals.:D
   / 50hr front axle oil?? #20
N80 said:
The Kubota manuals really aren't causing the confusion. Its in threads like this that cause the confusion. If the manual for his tractor says to change it at 50, that's when he should change it, regardless of what the manual for someone's BX or M calls for. I'm not fussing, I'm just saying, for any given model, simply follow the recommendations for that model....
I guess I'm just easily confused then :rolleyes:
The attached scans are from the same Kubota manual that covers all the Grand L 40 models from the L3240 - L5740. As I have posted previously, I find this Kubota manual "confusing" on the subject of when to change the transmission fluid...
The Maintenance Service Intervals table (GL40 Maint Table.jpg) indicates to "Change Transmission fluid" every 400 hours. And the detailed service instructions referenced on page 99 (GL40 Hydraulic Filter.jpg) describes that procedure in conjunction with replacing the hydraulic oil filter. BUT....
The Maintenance Service Intervals table also indicates to "Replace the Transmission oil filter" every 200 hours (as well as at 50 hours) without "Changing Transmission fluid". BUT the first step in the detailed instructions on page 96 (GL40 Trans Filter.jpg) for "Replacing Tranmission Oil Filter [HST Type]" reads...
"1. Remove the drain plugs at the bottom of the transmission case and drain the oil completely into the drain pan." along with a line drawing of all three drain plugs required to dump the full 11 gals of UDT.
and is followed up by...
"6. After the new filters have been replaced, fill the transmission oil up to the notch on the dipstick"
So maybe one of the 'Kubota manual literalists' can tell me how I can follow ALL of these instructions in my manual without filling "the transmission oil up to the notch on the dipstick" using the 11 gals of UDT I just drained completely :eek:
Talon Dancer
FWIW I have a nasty habit of thinking for myself. So, I can't remember ever following ANY instructions/manuals literally. I changed all 11 gals of UDT at 50 hours and will just replace the filters -- and the lost UDT with new UDT -- at 200 hrs (probably at the end of this week). Then I'll change out the full 11 gals of UDT again at 400 hrs.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55852)
2004 Pierce Tilt...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Electric Mobility Scooter (A54815)
Electric Mobility...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A56138)
2009 FREIGHTLINER...
