robbo323
I have a front-mount 2750C snowblower attached to my BX2350. "Found" a 2x4 that got left in a bad place and snapped both shear bolts for the first time on the main auger shaft. I replaced both bolts, but I noticed that where previously there was an equal small gap at each far side of the shaft - basically it was perfectly centered, now the auger shaft is shifted to butt up against the left side and there's about a 1/2" gap on the right with the underlying shaft exposed. With the shear bolts in where they belong, its all locked in, so it can't be nudged back over. I can't even get my head around how this happened without some kind of horrible damage to the gearbox in between. What happened? Think I can leave this alone? Incidentally, I finished the driveway before I noticed this problem and it seemed to work fine. Thanks.
