OK., I think I am getting a good buy on a tiller. The guy says it is a Kubota tiller he is checking if it is the 37" he pretty sure it is. He wants $550.00 for it. Guess my question is when I inspect it what do I look for? and if it larger that the 37" how large can I go and still run with my BX24? /QUOTE]
I run a 50" with my b7100, 37" seems small as you have more horsepower than I do.
Will that 37" cover the width of your tires? If not can it be offset so you can cover at least one tire track? Can it be hooked to a tractor and spun up? if so it should run pretty quiet when not in the ground. If there are major problems with chain or gearbox I think you would hear it. Check the tines, a new set for my tiller was about $150. Does it looked like he kept grease in it i.e. maintained.
Charles
