HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 03-08-2008, 12:12 AM   #21 (permalink)
Gold Member
Default Re: Sad day for my B6100 :-(
I have a parts PDF but the number in it did not bring up any hits.
__________________
Mike
KubotainNH is offline   Reply With Quote
Old 03-08-2008, 09:48 AM   #22 (permalink)
Quote:
Originally Posted by KubotainNH
I can try, it's a small garage so not sure how far I can get back. After I posted them I was thinking some were too detailed. These ones were more for knowing how things will go back together. Here's a question for someone who's done this on one of these little tractors, where'd you get the tool to line up the clutch disk? Will an auto parts place have one to fit? Thx.
You can eyeball it or trace the shaft back towards the rear end and there is a coupler, loosen that and you can extend the shaft forward a few inches... this was just enough for me to get the clutch aligned etc when putting it back together.
charlz is offline   Reply With Quote
Old 03-08-2008, 09:59 AM   #23 (permalink)
botamike's Avatar
I just go thru a couple of our local dealers for parts on my B6000. While not as cheap, I feel a bit better supporting the local businesses when I can. I am saving your pics as future referance for when I have to split my B series, the 6001 is about as close to the 6000 as one can come unless your working on one. Good luck and let us know how it turns out. Mike and Michele T
botamike is offline   Reply With Quote
Old 03-08-2008, 10:46 AM   #24 (permalink)
Mike...re centering the clutch disc...I have had great luck over the years using a piece of an old broom handle or a wooden dowel of the correct diameter to fit through the splined hole in the disc. The wooden broom handle with a rounded end works well to center in the pilot bearing, otherwise I whittle the end of the dowel to fit the pilot, being careful to centre my whittling. The last clutch I replaced actually came with a plastic tool that saved me the whittling!
Good luck with it.
__________________
Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 72" rear snowblower.
herringchoker is offline   Reply With Quote
Old 03-08-2008, 01:17 PM   #25 (permalink)
Send a message via AIM to texbaylea
Most auto parts houses have inexpensive (plastic) alignment tools to line up the clutch plate. You will need the ID of the pilot bearing and the OD of the splines on the input shaft. Probably will be metric. I have a universal tool that is SAE that I have been using but the cheap tool is adequate.
Vernon
__________________
Kubota L3130HST, LA723 Loader w/QA, 6' BB, 6' Bush Hog, 5' RB, PHD, ATI grapple, Hy-Reach Tree Shear, toothbar, pallet forks, grubbin bucket.
texbaylea is offline   Reply With Quote
Old 03-08-2008, 03:36 PM   #26 (permalink)
Gold Member
Thanks for all the tips. When I did my car I had a plastic tool, but I figured the tractor may be different than cars but maybe not. As for my local dealer, they are quite a drive and they don't impress me much. I have no issue buying stuff locally if they act like I'm the customer.
__________________
Mike
Old 03-10-2008, 06:01 PM   #27 (permalink)
Gold Member
Here's a couple pics from back a bit. Please disregard all the stuff in the garage.
__________________
Mike
Old 03-17-2008, 06:14 PM   #28 (permalink)
Gold Member
The old tractor is finally back together and running. I did have a glow plug issue, just a loose connector though. The clutch pedal is now adjusted properly so hopefully this clutch setup will last forever. Total time somewhere between 7-8 hours including some repair work. It's good to hear the old diesel run.
__________________
Mike
Old 03-17-2008, 07:34 PM   #29 (permalink)
Good to hear you've got it up and running again.
__________________
Old 03-17-2008, 07:57 PM   #30 (permalink)
gotcha's Avatar
Great to see you have it up and running. It doesn't look like the small work space helped you doing your repairs. What did you end up using to align the clutch plate etc. Not a broom handle hopefully.
The Gotcha Man
__________________
gotcha is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
