botagreen
I have a Kubota B7610 HST thats a little over a year old with about 200 hours on it. Two questions I would appreciate your help with:
1) I have recently begun hearing some sort of squealing noise that seems to be coming from the transmission. It is not an extermenly loud squeal but it is definitelty noticeable; almost like a spinning sound with a squael if that makes any sense. It occurs intermittently in both forward and reverse, with and without the 4wd engaged. It is intermittent and seems to quiet itself when I let off of the drive pedal and slow down just a bit. I performed my 50 hr service as called for, used Kubota fluids, check the tranny fluid frequently and I always let the tractor warm-up for about 5 minutes or so before driving it. Although I have worked it very hard over the last 6 months clearing land around my home on weekends, I do not feel I have abused it in any way. Any ideas as to what may be the problem ??
2) Every time I check the tranny fluid, I pull the dip-stick out and it is dry, (which seems a little bit odd to me). I then put it back in and when I pull it back out (gently), the fluid is always on the dip-stick, exactly on the line it is supposed to be on. Is it normal for there not to be fluid on the dipstick when I first pull it out ??
Thanks a lot for taking time to read this. Hope you can help.
