I just attached a 7' KK landscape rake to my new B2620 and noticed a couple of problems. When I first hooked it up, the tube running from the 3PH triangle rake pivot point (not sure what this is called, by I'll call it the "top tube" for short), was not parallel to the ground when the rake was lowered. The rake side of the "top tube" was much higher than the 3PH side. This has two negative consequences:
I figured the solution is to lengthen the top link until the rake "top tube" is parallel with the ground when the rake is lowered. Sure enough this works. Now if I raise the rake a very small amount off the ground, I can swivel it in either direction and the rake remains parallel to the ground. This all angled the tines more forward rather than upright. However, this created a couple of problems:
http://www.tractorbynet.com/forums/attachment.php?attachmentid=98014&stc=1&d=1205563757
There is room to drill another hole in the lift rod 2" to 3" above the current hole. This would raise the rake about another 5", which would be enough for transport. Would this be OK to do? Should I just get a shorter lift rod?
thanks,
Chris
- The tines are too upright and not angled forward enough.
- When I angle the rake, the side that is more forward is also quite a bit lower.
- The top link is adjusted to within 1/4" of its maximum length. I'm guessing this weakens the top link, making it more prone to bending. Is this true? Should I be concerned about this when using a landscape rake? Should I get a longer top link?
- The lower links need to be almost fully raised in order to get the rake "top tube" parallel to the ground. Because of this I can only lift the rake 2" inches off the ground. I really need to shorten the top link some before transporting the rake.
thanks,
Chris
