HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-24-2008, 09:08 AM   #1 (permalink)
milkman's Avatar
Default BX torn boots, another solution.
I'm thinking this might work and at $8 and change for the hose, seems cheap enough to me, added two hose clamps and about fourty minutes work. The first pic is of the grossly wrong WHITE wire tie that had to removed and placed into the bottom of the trash barrel UNDER the rest of the garbage before I could even begin. Looks like I might have another project on the horizon, leaking O-ring on the steering will need to be replaced.
bx-torn-boots-another-solution-whttie.jpg  bx-torn-boots-another-solution-blktie.jpg  bx-torn-boots-another-solution-solution.jpg  bx-torn-boots-another-solution-problemfix.jpg
__________________
"Wisdom doesn't necessarily come with age. Sometimes age just shows up all by its self" (Tom Wilson)
milkman is offline   Reply With Quote
Old 04-24-2008, 01:05 PM   #2 (permalink)
Default Re: BX torn boots, another solution.
The ability to improvise, a strength of the American character. Nice work!
Tom_H is offline   Reply With Quote
Old 04-24-2008, 01:18 PM   #3 (permalink)
I like the radiator hose idea...simple easy and doesn't take a master fabricator to well fabricate....
__________________
Kubota BX24 Enfield, NH
offcamber is offline   Reply With Quote
Old 04-24-2008, 05:16 PM   #4 (permalink)
Gold Member
Quote:
Originally Posted by milkman
...I'm thinking this might work and at $8 and change for the hose, seems cheap enough to me, added two hose clamps and about fourty minutes work...
The best ideas are often the simplest; thanks for sharing it with us.
Great work MilkMan!
__________________
Currently own a BX24... once had a BX23... a BX22... and a B7100HSD... All great workhorses!
lp333 is offline   Reply With Quote
Old 04-24-2008, 06:35 PM   #5 (permalink)
Nice job, milkman.
I was think of doing something exactly like this after patching one of my boots the other day. Is that hose a generic flexible hose? What is the ID of the solid ends?
Did you check the steering at full lock in both directions? When I looked at mine, it looked like there wouldn't be much room to clamp the hose on the inside of the large diameter section because it gets real close to the steering rack.
Can you take a pic with the steering full over so the inner tie rod joint section is as close to the rack as it gets?
Thanks!
__________________
BX24, Gearmore tooth bar, Bro-Tek thumb, ripper, & skid plates, American Solutions grapple, 4' Woods box blade, 5' Gearmore rake, Bearcat 70554 chipper, Ramsplitter 18-ton 3-point splitter. Not enough time to use them all!
mpowrd is offline   Reply With Quote
Old 04-24-2008, 06:37 PM   #6 (permalink)
My boots have been gone for years. Idly worrying about it has been effective so far. A thousand hrs later the joints are still tight.
larry
SPYDERLK is offline   Reply With Quote
Old 04-24-2008, 07:26 PM   #7 (permalink)
milkman's Avatar
mpowrd, just got in, been tilling most of the day, I'll run out in the mornin' and get some more pics with the wheels turned. I went to Advance Auto Parts and bought the shortest piece of 1-3/4" radiator hose that they had and placed the clamp around the hose where it is over the large nut on the end of the steering cylinder and I haven't noticed a problem with turning yet.
__________________
Old 04-24-2008, 07:49 PM   #8 (permalink)
Thanks! I'll look forward to the pics.
Next time I'm by the auto parts store I'm going to get a hose to chop up. Got more brush to move and don't want to tear up those boots.
__________________
Old 04-25-2008, 09:02 AM   #9 (permalink)
milkman's Avatar
Here's two pics of the right front turned hard left.
ID:	101174  bx-torn-boots-another-solution-rthrdlt2-medium-.jpg.JPG
__________________
Old 04-25-2008, 09:05 AM   #10 (permalink)
milkman's Avatar
Here's two of the left, nothing interfering anywhere.
ID:	101176  bx-torn-boots-another-solution-lthrdrt-medium-.jpg.JPG
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
