HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-08-2008, 10:55 PM   #21 (permalink)
New Member
Default Re: LA724 loader VERY WEAK!
A few pictures of the loader in action.
la724-loader-very-weak-dsc_0047small.jpg  la724-loader-very-weak-dsc_0063small.jpg  la724-loader-very-weak-dsc_0073small.jpg
L3240 is offline   Reply With Quote
Old 05-09-2008, 12:59 PM   #22 (permalink)
cschlaps's Avatar
L3240, what grapple and toothbar is that on your tractor?
__________________
L3240HST with LA724 loader, loaded R1's, 2 worklights, 72" HD bucket, BH90 with 18" bucket, 6' BB, 7' RB, 7' LR, Bradco forks
cschlaps is offline   Reply With Quote
Old 05-09-2008, 01:44 PM   #23 (permalink)
New Member
Quote:
Toothbar - EZ HEAVY DUTY TOOTH BAR ATTACHMENT
Grapple Kit - Rankin Equipment Co.
Navigate to Farm -> then Grapple Kits
Old 05-12-2008, 08:53 PM   #24 (permalink)
Member
I was wondering the same thing with my loader. I am used to by TLB and using the lift and curl at the same time when loading the bucket. I thought it was a bit weak too until I tried just using the lift by itself and it seemed much stronger.
I was looking at the installation manual for the loader and there was not anything about setting the relief valve for the 724 vrs the smaller loader.
My question is, is the relief valve part of the tractor or loader and is it set any different for the smaller loader vrs the 724?
__________________
GL3240 HST, 724 FEL, Loaded R4s, Squealer 160 Bush Hog, 72" Box Blade, and more to come.
Ford 655 TLB
Cat D6B Dozer
Chev C70 Dump
Just having fun in the dirt....
slan is offline   Reply With Quote
Old 05-18-2008, 03:19 PM   #25 (permalink)
New Member
The relief valve is part of loader valve.
Old 05-18-2008, 04:19 PM   #26 (permalink)
IU have a friend who has a L3240 with the same loader and is as dissappointed as the rest. Same problems, no balls with stone and otherwise full buckets. I guess he is also comparing apples to oranges as he has the full line up of big iron. Having seen his machine in action....and then comparing it to our L48s, I too thought the 7series loader was "over spec.ed" by Kubota.
curtisfarmer is offline   Reply With Quote
Old 05-18-2008, 10:18 PM   #27 (permalink)
Member
Quote:
So, if the loader valve comes with the tractor standard without a loader.
Front Loader Hydraulic Valve
Kubota has designed an integral Front Loader Valve as part of the tractor. With this valve, you can quickly and easily attach the front loader and other front-mounted implements. The valve promotes efficient, clutter-free operation and matches the sleek styling of the tractor. If you don't require a front loader or other front-mounted implements, an optional Diverter Kit is available to allow the loader valves to function as rear remotes.
The same question.
Which loader is it set for as default?
__________________
Ford 655 TLB
Cat D6B Dozer
Chev C70 Dump
Old 05-18-2008, 10:29 PM   #28 (permalink)
I think they stick out to far in front of the tractor and you have to use way to much weight on the back. Sure that takes away some reach but I would give up reach if I didn't lift the rear wheel off the ground. I feel for small loads( load of gravel ) you should need no more then the tires loaded. I put the tires at max width and that helps that 3 wheeling. Power on mine seems short also but haven't check the PSI yet and the way the rear comes up I'm not sure if I well change if it is low. Lee
Leejohn is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
