Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    May 2008
    Posts
    1
    Default L2350 Wont stay running
    Late 80's model L2350: Will fire and sputter, but wont stay running. I cracked the fuel filter and got flow out of it. (I will pick up a new one this week). What else could it be?
  2. #2
    New Member
    Join Date
    Feb 2006
    Posts
    8
    South Central Louisiana
    Kubota BX 2660
    Default Re: L2350 Wont stay running
    I had a L2350 and if you do not crack the screw on top of the fuel filter and also the one on the fuel pump you will never get it started. You need to open both at same time to get all the air out then close the one on the filter first then the one on the pump, Hope this works for you
  3. #3
    New Member
    Join Date
    May 2007
    Posts
    8
    Louisiana
    Kubota L2800DT
    I had a L2350 and Cajunbota is right about the starting after running out of fuel sequence. Had to do this several times as the L2350 has no fuel gauge.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
