#31 (permalink) |
Member
I would try to straighten it out. auto press and a lot of safety equipment. Ive straightened out a steering cyl on a case 680. Then you can have a spare cyl.
__________________
B7800 HST, fel, woods bh70x with thumb, Markham tooth bar. |
#32 (permalink) | |
Quote:
#33 (permalink) |
Rod bending on a back-hoe cylinder is much more common than you may think. I've got 2 cylinders right now off of back-hoes with bent rods. The brod is the weak point on a back-hoe, believe it or not. Here are 2 rods, one is 2" the other 2.5", both pretzels now.
__________________
Knowing is not enough, you must apply. Willing is not enough, you must do. Bruce Lee |
#34 (permalink) |
Quick update.
I installed the new cylinder Friday PM, without any difficulty. Just a matter of removing a couple of bolts and pushing out the pins, transfering the hydraulic fittings, zip, zip. Probably a 30 minute job taking my time being sure to get everything right. I greased all the fittings on the BH, and FEL while I was at it, worked the bucket a few times, filled up the hydraulic fluid reservoir, and was good to go. Stump is buried, and the area is graded, fertilized, and seeded. Today I faxed the receipt for the cylinder and 1 gal. fluid to the insurance company. I'll let you all know when/if I get a check, but that the story for now. |
#35 (permalink) |
Final Chapter.
I actually received a check in the mail. The Insurance covered the damage including a gallon of SUDT minus the $250 deductable. Grass is already growing where the stump once was, and the graduation party Saturday was a big success. Even the rain which was forcasted to be on and off all day, held off until late in the evening when most were already leaving. Now I'm ready for the next "big dig". |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
