HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Trackback Thread Tools Search this Thread Display Modes
Old 05-16-2008, 04:05 PM   #31 (permalink)
bx24
Gold Member
bx24's Avatar
Default Re: Replacing BX fan w/electric fan
Here is a couple of pictures
replacing-bx-fan-w-electric-svcompucycle_2000_102335210.jpg  replacing-bx-fan-w-electric-svcompucycle_2000_100768369.jpg
__________________
Paul
BX24
bx24 is online now   Reply With Quote
Old 05-16-2008, 07:10 PM   #32 (permalink)
BotaBigot
Existing fan just might reverse. Worth a try with a quarter-inch ratchet. Put cardboard against radiator to protect fins. If it works, this would be elegant in its simplicity.
I think your "cookie sheet" would totally restrict airflow and overheat.
Playing devil's advocate...if you would go to the trouble to install microprocessor coolers, why not just put in the heater core...
__________________
John
BX24, Loaded R4s, 60" MMM, Rear Bagger, Woods RCC42, 3PT Splitter, TuffTop, Buncha Bro-Tek...more to come
BotaBigot is offline   Reply With Quote
Old 05-16-2008, 07:52 PM   #33 (permalink)
SPYDERLK
Turning around a fan blade does not reverse the airflow. Reversing the slant just makes it turn out the same.
larry
SPYDERLK is online now   Reply With Quote
Old 05-16-2008, 09:37 PM   #34 (permalink)
escavader
escavader's Avatar
PAUL,
SORRY ive been away this week.Looking at your pics,your floorboard looks the same as the 23 ,except we dont have that plastic thing under the battery box.If you could remove that,id bet your metal floorboard under it comes out as ours does.If not Mabey you could design a freshair vent to feed in the battery compartment [after you plug the screen up to keep your air in your cab]so that the radiator has fresh air.In my opinion id go with one of these options before i started messing with fans.
Get some tools and take that battery compartment apart and see what you got .Cant tell by the pic what that plastic thing is,if all it does is hold up the battery box,a redesigned box is easy.
ALAN
__________________
KUBOTA BX-23,LOADED AG TIRES,MECHANICAL THUMB,SALSCO CHIPPER,WOODS LRC60 LANDSCAPE RAKE WITH GAUGE WHEELS,,BUCKET FORKS,QUICK HITCH FOR 3 POINT HITCH,FRONT BUCKET-QUICK HITCH, FARM FORCE 6 FT 3POINT BLADE,MARKHAM TOOTHBAR,TRAILER HITCH FOR BACKHOE, HOMEMADE STEEL CAB,54 INCH PRONOVOST PUMA 3 POINT SNOW BLOWER,WITH HYDRAULIC CHUTE CONTROL
escavader is offline   Reply With Quote
Old 05-17-2008, 07:57 PM   #35 (permalink)
BotaBigot
Quote:
larry
Yep...that's what happens when you focus on the word "reverse" instead of thinking...
__________________
John
Old 05-17-2008, 11:40 PM   #36 (permalink)
NY_Yankees_Fan
NY_Yankees_Fan's Avatar
Paul,
I went the electric heater route and found it did not produce enough heat to keep me warm. In fact send me a PM and u can have the electric heater I used for the cost of shipping. I ended up going with a heater off the engine cooling system. That works great, I can snowblow with no jacket.
__________________
AKA Tom
Kubota BX 2200, FEL, 60" MMM with Gator Blades, 48" Kioti Aerator, M96 Herd Seeder, W.R. Long Tooth Bar, 48" First Choice Tiller, Kubota BX 2750 Front Snowblower, Sims Cab, MacKissic Chipper TPH 122, Carry All, Canopy, and Weight Box,
Kubota Ready for Winter http://www.tractorbynet.com/photos/s...php?photo=1212 http://www.tractorbynet.com/photos/s.../cat/529/page/
NY_Yankees_Fan is offline   Reply With Quote
Old 05-18-2008, 05:13 PM   #37 (permalink)
bx24
Gold Member
bx24's Avatar
John-
I was thinking about using the cookie sheet to restrict the flow to cause things to run hotter knowing that I was going to expel the heat inside the cab with the CPU coolers. Because of my assumptions with the coolant flow rates, I am basically using the CPU coolers as heater cores. I just like the mounting flexibility that comes with the CPU coolers. What is the normal in and out sizes for an automobile heater core? 5/8 or 3/4? I figure the main radiator would still provide some cooling (given the cold outside temps) with the two CPU coolers picking up the rest of the load. The main thing was that I did not want to be sucking all of the warm air our of the cab.
__________________
Paul
BX24
Old 05-18-2008, 05:17 PM   #38 (permalink)
bx24
Gold Member
bx24's Avatar
larry
Honest to God I thought that was the case, but after starring at my own picture for 5 minutes, I talked myself into the idea that it would do what I wanted it to. If anyone wants to make some quick bucks, in my present condition it would not be hard to sell me a bridge or some swamp land!
Well if flipping it around would not work, what if I turned it upside down?
__________________
Paul
BX24
Old 05-18-2008, 07:38 PM   #39 (permalink)
638
Gold Member
You'll lose the oil out of the engine.
ron
638 is online now   Reply With Quote
Old 05-18-2008, 09:14 PM   #40 (permalink)
BotaBigot
Quote:
Originally Posted by bx24
John-
Heater cores can use both sizes, some even one of each.
I'm concerned that CPU water coolers may not provide enough heat transfer, given the variables of outside temp and engine loads. However, that black plastic under the battery looks like it might deflect some airflow under the tractor. If so, your "cookie sheet" on just the upper 2/3 would block airflow thru the cab and possibly still allow enough winter cooling. Worth investigating.
__________________
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.18427 seconds with 11 queries
