#11 (permalink) |
Someone mentioned leach fileds and lawns.....I do alot of lawn installs and many atop leach fields. First is the fact that all contractors suck *** when it comes time to do thelawn right the first time, the usually put down just enough to get germination and then close on the loan. Second problem is unknowing homeowners or stupid landscapers use wheeled machines atop leach fields to do the rebuild. A BIG no no. Wheeled machines hauling dirt atop a leach field compacts the soil of the leach system and eventually eroding the lifespan of the system. The ground pressure from wheeled machines is too much for the porisity required for the designed system. I use L48s for my company and with dirt in the bucket I simply refuse to work atop septics in case of compaction. I bucket the dirt on the side and then use my KX121-3 with grading bucket to spread the topsoil. The tracked machine is low ground pressure and is the only safe way to install such a lawn. My average lawn install is over 100 yards of sifted topsoil with a 4" minimum depth. People don't realize how expensive lawn installs are, except the scamming contractors who know exactly how much it costs....and how much they can save by skimping. At least 25-30% of my business is fixing things that where not done right the first time. I take every bit of dirt home to my yard and I must have 400+ yards of soil "aging" and ready to be sifted and shipped out. I pay $18 a yard delivered, others charge $25 + delivery. I use my raw topsoil for landscape construction and things where sifted isn't needed much. When you add up the soil, seed, machines, and warranty costs..it adds up big time. Last year I did more lawns than I ever have, then had the driest August on record, and many warraty reseeds which eats at the profit. This year I am only doing hydroseeding which I pass the warranty claims along to my hydro sub contractor. Lawns take at least 1 year+ to establish, and only with regular maintenece, spot reseeding, fertilzing and thatching do they come out great. Lawns are one of the toughest parts of landscape construction.
#12 (permalink) |
I fight a similar issue - sandy soil and pea gravel on top of clay and 20+ degree slopes. If grass hasn't taken hold, every rain brings the gravel to the surface - like walking on ball bearings....
before I got the BX, would just use a drag on the lawn tractor and rake and shovel. Get the gravel off the surface, plant seed, straw and hope no big deluge came before the seed took. I started attacking in sections, because some areas were deep shade and others more sunny. I also learned to not perform weed control the first year or two - just lime and fertilizer - ANY vegetation was good if it took hold with the seed. Once the ratio of grass to weed was high enough, would start the weed control. Right now after 6 years, my front is thick with no weeds (been good the last 3 years - was my first section) This year the sides and most of the back have come in - almost an acre worth If I had had the BX I probably would have brought in soil - or tried screening - now I'm extending the yard into the woods a bit more - but the soil there is good
__________________
'07 Kubota BX24 Rookie Driver (62 hrs) Facts are meaningless. You could use facts to prove anything that's even remotely true! --Homer Simpson |
#13 (permalink) | |
Quote:
My leach lines are buried at least 6' below the surface, if not more, because they are on an uphill grade from the septic tank, which is two feet below grade itself because it is slighly up hill from the house. I plan on dumping about 100 or 200 yards of muchroom compost on the field using a 5 yard dump truck this summer. Because of how deap the leach lines are, and the fact that we won't have had rain for 5 months by the time I do this, I think they will be fine. The soil will be like concrete by then. BTW, the muchroom compost is free and just a 1 mile down the road. I'm hoping to get at least 4 runs per hour done. |
#14 (permalink) | |
Elite Member
Quote:
Fertilizing cycles and the type of fertilizer really depends on the type of turf you are growing. If the soil in your area is real acidic it can be hard to put too much lime down but you sure can put too much lime down. It is all about getting the PH to the proper place so the plants can use the nutrients in the soil. The only accurate way to know how much lime or fertilizer is required is with a soil test. Your local county extension agent or farm co-op generally provides soil testing services at reasonable prices. With the cost of fertilizer these days it is good to know how much you really need. MarkV |
#15 (permalink) |
Interesting enough, my friend who installs septic systems claims as much water evaporates upward as does downwards and that is why most systems are close to the surface with slightly less than 1.5' of cover. It depends on your soil type as to what your design is, but more times than not the contractor skimps on the topsoil.
#16 (permalink) |
Member
I had a call today from a customer who wanted an estimate to actually remove some stumps and make a lawn for their new house,actually they have 6 new homes all rental units, well I went to have a peek and see what they actually wanted,the first thing I spotted was the septic beds appox 4 feet above grade and 6 foot alders growing on the bed,not a bit of topsoil all sand.
I first looked at the stumps,not a major job to remove and cover with some topsoil,lime, fertilerize,and seed gave them a price to do all their properties and got the go ahead will start next week. Than the lady said how about the septic systems; I told them up front they were not properly finished and were a mess to which they agreed. Than the question. Can you fix? Yes I can fix but its not cheap,what I proposed to do is cut and remove all the alders and spray with roundup,than cover with 4 inches of mixed topsoil,peat and rotted cow manure,than lay sod.I could seed however with the slope I figure with a heavy rain it would wash out where as I can stake the sod until it becomes rooted and than its a simple matter of running over it every couple of weeks with a lawn mower. More problems these people are from Germany and only here a few weeks a year and they don't want to have to maintain lawns . Yep I can send a crew out to mow the septic systems once a month but we are 60 miles away our travel time would be more than our actually labour. These people are from Germany. Does anyone have any ideas on how I can assist these people? I am open to all suggestions;however what I suggested is the best I can come up with, money is not an object with these people however I don't want to seem to be taking advantage of them. |
#18 (permalink) |
If you have to sub contract it, you shouldn't be doing the work anyways. Bad mojo, too many things can go wrong. I got screwed once and I said never again. Made me look real bad and I lost a major customer. Just some advise.
#19 (permalink) |
I know for proper fertilizing I should have my soil PH tested. But I was wondering if anyone knows how well those little jobbers you stick in the ground work? Has anyone seen these?
I don't mind bringing samples to the local co-op, but just thought it'd be nice to be able to test maybe more often or w/out the trip to the co-op. Just wondering. j
__________________
j L3400 HST, LA 463 FEL, 6' Woods blade, 65" Woods box blade, 60" Meteor blower, CCM top & side links, 2 extra rear remotes waiting for a use and a big, fuzzy hat |
| Thread Tools | Search this Thread |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
