HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-08-2008, 02:05 PM   #1 (permalink)
Default Using implements from diffrent tractors?
Hi. I have a BX24, just done 100hours since november-07. A friend called me and asked me to help him with the hay. Heエs runnig a small bale machinery which would fit my BX. So far no problem...I realised that I need adjust/fit some other hydralic valves where backhoe runs, that wouldnt be to big problem. But what I didnt like was the idea to use "normal" implements which uses standard hydralic oils, or at least they have some hydralic oil left inside the implement which my BX will get. Kubota is using fully syntetic hydro oil (SUDT) and normal farm implements are using standard hydro oil. How bad is it to mix these diffrent oils? Do I need to drain the implements Im loaning?
Thanks,
/Sam
samofsweden is offline   Reply With Quote
Old 06-08-2008, 03:24 PM   #2 (permalink)
Default Re: Using implements from diffrent tractors?
Quote:
Sam,
SUDT is not synthetic, it is a multi viscosity, UDT. It is just priced like a full synthetic. Lots of people have thought that is what the S stands for
A BX24 dose not have a large capacity hydro reservoir so contamination is easier than with a larger tractor
I am curious, what kind of bailer is small enough to operate on a BX? KennyV
KennyV is offline   Reply With Quote
Old 06-08-2008, 04:29 PM   #3 (permalink)
Thanks,
/Sam
That baler is going to shake that BX all over the place! After watching a friend using a squalre baler on behind his L5030...I wont even hook it up to my B3030....not enough MA$$ to offset the shaking
__________________
Kubota B3030 with 40 amp alternator kit; LA403 FEL; 60 inch backblade; sub-soiler; ballast box; EzMover hitch; Payne clamp-on bucket forks; a HD set of smaller discs and a 60" landscape rake with dolly wheels
Hobart HH140 Mig welder
Hobart HH210 Mig welder
Sully2 is offline   Reply With Quote
Old 06-08-2008, 04:47 PM   #4 (permalink)
Elite Member
RobJ's Avatar
Quote:
Boy this was my question to. Wow!
__________________
L2500
RobJ is offline   Reply With Quote
Old 06-08-2008, 05:08 PM   #5 (permalink)
Hi guys!
Its a minibale machine, the bales are made for horse people when they are on competitions, then they can carry a few bales with them in their trailers. But I havnt tryed yet...so you guys might be right Its late over here, I will post some pics tomorrow of the bale machine.
Thanks for your input!
/Sam
Old 06-08-2008, 08:22 PM   #6 (permalink)
ChuckinNH's Avatar
Now, if someone would adapt all the implements that go on a BCS two wheeled tractor for use on the BX series we would have some useable stuff! They have a baler.......... and I'll bet even I could lift the bales.
__________________
B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, and more to come...
ChuckinNH is offline   Reply With Quote
Old 06-09-2008, 12:16 AM   #7 (permalink)
Quote:
Sounds like you having same way of thinking You can carry these bales up...depends how much water there is in the grass. I cant find any pics on the bale machine
Old 06-09-2008, 01:29 PM   #8 (permalink)
ChuckinNH's Avatar
I know what size bales you are talking about, and that baler is too big to run on a BX for sure! Careful with wet bales too. They will really heat up when piled, and can burn a barn down very quickly!
__________________
Old 06-09-2008, 02:04 PM   #9 (permalink)
CumminsLuke's Avatar
I think he is talking about something like this...................
http://www.tractorhouse.com/listings...9A6B27E94F6FB4
They are little bitty bugers.
__________________
-Kubota M7040, hydraulic shuttle, 4x4, cab, LA1153 loader, two remotes, washer fluid in rear tires, quick tach 84" bucket, quick tach bale fork
-Kubota M6040, hyd shuttle, Rops, 4x4, LA1153 loader
-Ford 1320, 2wd, hydro, turf tires/landpride finish mower
-Kubota RTV900 worksite
-Kubota ZD21 60" pro deck
-Ford 2N
CumminsLuke is offline   Reply With Quote
Old 06-09-2008, 03:22 PM   #10 (permalink)
Hi Just found a pics from the small bale machine, it needs 11-15 hp 80cm wide. The bales have a diameter at 57cm and lenght 63cm
I think its made in Italy.
/Sam
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
