#1 (permalink) |
Member
I want to install some aux work lights on the rops and was wondering where the best location to take power from. Is there a place on the fuse block that can be used?
Where do most people connect to. Thanks....
__________________
GL3240 HST, 724 FEL, Loaded R4s, Squealer 160 Bush Hog, 72" Box Blade, and more to come. Ford 655 TLB Cat D6B Dozer Chev C70 Dump Just having fun in the dirt.... |
#2 (permalink) |
Location: Pendleton and Meacham, OR the coldest place in Oregon
To the right and rear of the operators seat. There are 2 plug ins that are for acc. I mounted one light to the rear and 2 forward facing to the rops stationary bolts with "L" bracket.
__________________
08 Grand L3540 HST, R-1's, LA724 w/quick attach, Home made ballast barrel. 6' box blade, 6' landscape rake, Markham tooth bar Oh, and 74 inch Farm King snowblower
#3 (permalink) |
Oops, I guess I mounted them in the blank hole, just uses washers to take up space. The rear one just mounts to existing bolt.
__________________
#4 (permalink) | |
Gold Member
Quote:
I wish the photos from the above post would show in this post since this is a good place to mount aux lights for rear work. Others should take a look at this nice installation.
__________________
****** sixdogs "Make sure you sell all the puppies before your wife gets attached to them" |
#5 (permalink) |
I dont know what you mean six, do I need to repost or what??? or are you being sarcastic, ha, ha ha
__________________
#6 (permalink) |
A better view. Also notice a good place to have a hammer.
__________________
#7 (permalink) |
Member
Nice install indeed!
I never noticed the aux power outputs before. Guess I was too busy using it to look around. It sure is easy on fuel compared to my other iron. It also seems to be getting a bit more power after 35 hours or I have just learned how to use the hydro better. I was pretty impressed with the performace of it with the sq160 bushhog when I cleared a 4 achre field of 8' apple and cherry trees last weekend. Thanks...
__________________
#8 (permalink) |
Gold Member
blagg---not kidding; it is just a nice clean-looking install. I am going to take my rear light off the ROPS and install like yours. I think visibility will be better with fewer shadows.
__________________
#9 (permalink) |
Questions for the Grand L owners who have installed work lights:
1). Any body know what the nut on the ROPS is for, as shown in the attached picture? I have been tempted to install my 3 x 5 traps there, although Blagg's install on the ROPS hing bolt looks like it may be even better. 2). Three plug-ins under right side of operator's seat, are these for the work lights (10 amp fuse labeled "work light") , or are they for trailer lights as someone from an earlier thread had suggested? I will be installing two forward trapezoidal 55 watt halogens, and one rear 55 watt flood and from what I understand they will draw close to 14 amps, too much for the 10 amp work light circuit, so it looks like I'll have to go to the battery to draw power. Why couldn't Kubota have done it right, at the factory??
__________________
Happiness is 2 rolls of duct tape
#10 (permalink) |
Super Member
Location: First organized permanent settlement in the northwest territory
__________________
Tractors 2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500 Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe / 60'' MMM/Clamp on Forks/48'' MMM |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
