Modn
Just so you know I have had the tractor just over a month and it has 29 hours on it and loving it.
So I'm out cutting wood out back and pulled up to a tree that was leaning/partially uprooted and needed to be taken (about 12") no problem. So I drop the tree and hook the chain to it and to the forks on my tractor and proceed to pull it out to a somewhat more clear area to cut it to 9' lengths to take it back to my house. I get it where I want it and pull forward to loosen the chain and here an awfull grinding noise. I quickly kill the motor and proceed to get off and walk to the front. Antifreeze/coolant is dumping on the ground and I see a 1-1/2" log/tree sticking out of the front!! It came with the other tree and of course I didn't see it at all. I don't know how, but it missed the hydraulic cooler and pushed the radiator into the fan. I just happened to have a ratchet strap and hooked it to the radiator (junk anyway) and and to the guard on the front and pulled it back off the fan. I waited until it cooled off completely and drove it back, roughly 1000-1500' to the shop (stopped 3 times on the way). So the order list is 1-radiator, 1-radiator shroud. It pushed out the grille screen cleanly but I can put that back and it bent up the screen just in front of the radiator but I can staighten that out and put it back. The bad news is the radiator is $530ish Sooooo when I get it back together I am going to fab a brush guard of some sort and bolt it to the front bumper guard as I would probably unbolt it for winter when I might use my lights since it will be dark early. Any other suggestions???? I guess I got the 1st dent/scratch deal done with!!!!
