HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-20-2008, 11:45 AM   #1 (permalink)
actionaj's Avatar
Default BX7326 Rear Aux. Kit (install)
This weekend I installed the BX7326 Rear Aux. Kit on my 2350. This kit is very well made and very well designed. It was relatively an easy install probably taking 40 minutes at most. I only had two minor problems with the install. The first one is the bolt supplied with the kit to hold the valve onto the side of the transmission is wrong. The bolt supplied with the kit is a 12mm it should be an 8mm bolt. The 12mm bolt won't go through the valve and the boss on then side of the transmission is 8mm, no big deal. The second one is indexing and tightening the fittings on the valve before installing (per-instructions). You will need to leave the fittings slightly loose to line up with the steel lines. After all the lines are started, tighten down the fittings. This takes an assortment wrenches and crows feet line wrenches. Again no big deal.
This kit is very well designed the all the lines run nice and tight to the sides of the transmission. Operation of the levers is convenient and smooth. The QDs are in a good location to.
All I need now is to order a set of male QDs and top link cylinder.
Here are some pictures of the install.
bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-001.jpg  bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-005.jpg  bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-006.jpg  bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-007.jpg
__________________
BX2350
FEL, RCK54 MMM, 4' Farm Star BB, 5' Farm Star RB, 5' Rake
actionaj is offline   Reply With Quote
Old 07-20-2008, 11:47 AM   #2 (permalink)
actionaj's Avatar
Default Re: BX7326 Rear Aux. Kit (install)
More pictures.
bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-011.jpg  bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-013.jpg  bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-014.jpg  bx7326-rear-aux-kit-install-bx7326-rear-aux.-kit-015.jpg
__________________
BX2350
Old 07-20-2008, 12:42 PM   #3 (permalink)
ChuckinNH's Avatar
Wow! Thanks for the pictures, and words about the remote install. That is one slick looking installation. I wonder if there is a kit for my B2620 like that? I would think that you have more than doubled the usefullness of your set up with that addition. Keep us possted on how it works out, and thanks again for the great pics of the install.
__________________
B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, and more to come...
ChuckinNH is offline   Reply With Quote
Old 07-20-2008, 12:44 PM   #4 (permalink)
DGS
Hi
Judging by where the levers go that would be where my existing cruise control lever is located
I guess this kit would only fit the BXxx50 series then
Correct?
Regards
DGS
DGS is offline   Reply With Quote
Old 07-20-2008, 02:11 PM   #5 (permalink)
I think they have a kit like this for most of the tractors these days. Chuck, there is a blank off plate on your 2620 on the ride side just behind the cruise control and 3PH 1/4" valve controls. I think that plate is for the location of these 2 control valves.
My B3030 has a similar setup, and I am thinking strongly about putting it on my tractor, even though I don't have an immediate need for it.
I have seen a few setups that people have done with "surplus" parts, and you can get more capability for less money than the Kubota setup, but I personally am somewhat partial to the level of integration of the factory setup...
__________________
Kubota B3030, 72" MMM, 403 FEL, ATI QA with ATI HD Bucket, Landpride RB1572 rear blade
stimpee is offline   Reply With Quote
Old 07-20-2008, 02:18 PM   #6 (permalink)
Member
CaptPat's Avatar
Wow that's a nice looking set up. I hope the one the dealer is installing on my new B7800 looks that good.
CaptPat is offline   Reply With Quote
Old 07-20-2008, 02:23 PM   #7 (permalink)
Gold Member
Wish I could find a mechanic that did work as good as you do. Your bench looks like an operating table.
__________________
Mark Leininger
MarkLeininger is offline   Reply With Quote
Old 07-20-2008, 03:37 PM   #8 (permalink)
ChuckinNH's Avatar
Quote:
Ah, you are right, there is a blank plate just above the 1/4 inching valve. I'll have to see what that set up costs for my tractor.
__________________
Old 07-20-2008, 04:57 PM   #9 (permalink)
New Member
What do you plan on running with your new remotes?
HvyDuty is offline   Reply With Quote
Old 07-20-2008, 07:44 PM   #10 (permalink)
actionaj's Avatar
Quote:
First I am planning to get a hydraulic top link. Then add a pivot cylinder to my blade. From there the possibilitys are endless.
__________________
BX2350
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
