Gents,
First of all, let's be clear, these remote valves are not from Kubota. I called Kubota service and they confirmed that it's an aftermarket kit made in the US by??? Don't really want to know.
Parts ordered:
Valve kits : B7309, BL7343 et BL7363. - $680+58+233= $971
Rear work light kit : B7335 - $94.00
40 Amp Alt : B7311 - $204.00
I just installed the dual remote kit on a B2320, same kit for the B2920. Let me tell you that this is not a small task, and don't expect to simply follow the instructions, you will have to be creative. Everything needs to be adjusted, drilled or replaced. The black mounting plate had to be drilled to be mounted inside the ROPS with both valves installed. Mounting the bracket on the outside (as per instructions) was just plain ugly and was a disaster waiting to happen, it sticks out to the side further than the tire.... The valve handles are very cheap, the valve body is not much better. The hoses are fine, but the nipple and elbow assortment is just plain wrong. I was missing two pieces, one was just the wrong size and the other was missing. The overall kit is really an afterthought, don't expect any fancy engineering here, this is a backyard custom job. Get ready to disassemble your new tractor significantly, this was never meant to be done, it's obvious. I will scan the instruction, you be the judge.
I also ordered the rear work light, heavy duty alternator and other real Kubota kits, they all fit very nicely.
Good luck!
