HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-18-2008, 06:34 PM   #41 (permalink)
JDeerekid's Avatar
Default Re: Let's see your snow removal equipment
Quote:
Originally Posted by Ductape View Post
This year............
well aren't you just spoiled.
__________________
Montana 4340C w/loader, AgroTrend FU78 rear snowblower with hydraulic shute rotation, Horst 48" pallet forks, 3pt. 2-bottom plow, 6ft. bush hog rotarty cutter, 3pt. Woods 7ft back blade, 3pt. cultivator, 5ft 3pt. york rake, 6' KKII tiller, JD494 4-row planter. Future attachments: backhoe, grapple
JDeerekid is offline   Reply With Quote
Old 10-18-2008, 07:17 PM   #42 (permalink)
Hi Guys. I am a new member and relatively new BX owner.
I made this front blade attachment for my BX1850 and it uses the rear 3pt hitch to raise the front blade. I use the mmm lever control to raise and lower the blade and I can use the deck height setting to even maintain the same blade height if I wish to not drag it. I have not tested it on snow as yet but in time I will find out how well it works. Hydraulics are not needed. I will need to angle the blade manually.
lets-see-your-snow-removal-blade6.jpg  lets-see-your-snow-removal-blade21.jpg
scarlo101 is offline   Reply With Quote
Old 10-18-2008, 07:26 PM   #43 (permalink)
WayneB's Avatar
You are totally spoiled! You will be out there blowing snow in only a Tee shirt while the rest of us are out there with every piece of winter clothing we own and still freezing. Nice looking rig! Is that a new snowblower?
WayneB is offline   Reply With Quote
Old 10-18-2008, 07:32 PM   #44 (permalink)
JDeerekid's Avatar
Nice homemade setup.
Couple questions.
Is the blade wide enough when angled?
How much snow do you get?
Seems like you will want to upgrade to a blower or blade on the back also, so can you use the 3pt hitch withou lowering the front blade?
And where are your ROPS????
__________________
Old 10-18-2008, 07:54 PM   #45 (permalink)
The blade is 48" wide and it appears that it will be wide enough. It is an old craftsman that I converted. I put a 2" hitch receiver on the tractor and the blade slides into it.
We have had significant snowfalls here in southern Ontario over the last couple of years, so I am sure I will be testing it pretty good.
Yes I am not sure what I will be putting on the back as yet but have thought about a sander as well.
I took the ROPS off because the first time I mowed the lawn I went near a tree and it hit a large branch and the front of the tractor lifted. So now I can mow near the trees without have to be aware of the branches.
Old 10-18-2008, 08:00 PM   #46 (permalink)
Gold Member
bigdad's Avatar
Nuthin' Fancy...... Get's the white stuff out of the way.
bigdad is offline   Reply With Quote
Old 10-18-2008, 08:22 PM   #47 (permalink)
Gold Member
herringchoker's Avatar
Works well for me.
lets-see-your-snow-removal-snowmover1.jpg  lets-see-your-snow-removal-snowjan2-08-001.jpg
__________________
Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 72" rear snowblower.
Case 450 c/w 6-way dozer.
herringchoker is offline   Reply With Quote
Old 10-18-2008, 08:27 PM   #48 (permalink)
Elite Member
Ductape's Avatar
Quote:
Wayne, thats what i keep telling my neighbors..... watch for me blowing snow in a pair of boxers and a tanktop . I'll also have the tunes cranking! The blower came with the tractor, not new (from a dealer) but it had never been used. I just got done adding a diverter and hydraulic chute deflector, so i won't need to get out to make any adjustments. If it makes you feel any better...... i've eaten plenty of snow in past years!
Ductape is offline   Reply With Quote
Old 10-18-2008, 08:29 PM   #49 (permalink)
Super Star Member
Location: First organized permanent settlement in the northwest territory
Hay !
That's pretty .
Don't think I've ever seen anyone do that.
__________________
Tractors
2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM
South of Canton Ohio
L . B
LBrown59 is offline   Reply With Quote
Old 10-18-2008, 09:06 PM   #50 (permalink)
Super Star Member
1*The blade is 48" wide and it appears that it will be wide enough.
2*I took the ROPS off because the first time I mowed the lawn I went near a tree and it hit a large branch and the front of the tractor lifted.
3*So now I can mow near the trees without having to be aware of the branches.
1*I have a 60 '' blade on this BX1500 an with it fully angled I would not want it to be any narrower.http://i283.photobucket.com/albums/k...9/100_2313.jpg
2*You removed the wrong item from the wrong thing.
3*Apparently you aren't aware of the hazard you are now faced with.
__________________
Tractors
L . B
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 1.16841 seconds with 9 queries
