BH65 Dolly
   / BH65 Dolly #1
SnowRidgeME
Member
Central Maine
Kubota B2920
Hi Folks,
To pass on the idea, just built a dolly for my BH, very simple, inexpensive and works great. Bought 4" wheels from HomeDepot, length is 48", width in the rear is 40", 16" in front, used hardwood boards to connect the ends. See attached.
   / BH65 Dolly #2
Looks good. Simple but effective. Are the wheels a hard plastic or rubber? Have you noticed them flat spotting when left sitting in one place for a while? Does it seem stable side to side? It looks like it is only contacting in the center where the outriggers are. Maybe some shim blocks on the 4x4 towards the outside for stability? Curiuos? I definetly will be making something like this soon.
   / BH65 Dolly
There were two type of 4" wheels at HomeDepot, I believe both were hard rubber, and I got the harder of the two ($12ea), and it does flatten some but not much, actually helps keep it in place. Could order harder casters at National Caster. It is fairly stable, trying to rock it side to side just makes the wheels move. I was expecting to put shims on the 4x4 or under the bucket to stabilize it, but there is no need. I just used hardwood boards to connect the ends only because I had them, 2 2x6s would work, would have to make the front wider to accomodate the width.
   / BH65 Dolly #4
Very nice & simple
How heavy is the BH65 ? I have a BH90 and would like to build something similar.
   / BH65 Dolly #5
Nice job SnowRidge.
I cheated and used an old pallet for my BH75. Just attached 4 - 300 lb capacity HF wheels. I do have a newer pallet I'll probably swap the wheels to in the spring, but I wanted to see how well the old pallet holds up with the backhoe on it over the winter.
If you want to use a pallet, try to find one that was used for stone or tile - they tend to be a bit heavier duty.
Backhoe on dolly pictures from home & garden photos on webshots
   / BH65 Dolly #6
Realize this is an old thread, but wanted to thank you for posting it. I built a dolly for my bh65 tonight using your dimensions and a very similar design. It worked great!
2017 Ford Expedition SUV (A55853)
2017 Ford...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2020 Deere 50G (A53317)
2020 Deere 50G...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
WACKER NEUSON (A55745)
