My plow set up
   / My plow set up #1
Hvytrkmech
I told several members a while ago I would post pictures of how I adapted an old Fisher plow to the bucket of my B7610, so here they are. I apologize for the size, I do not know how to make them smaller.
Started with the bucket mods, 1/4 plate added to bottom and 45* angle toward rear of bucket. Also added hooks and angle to the top.
   / My plow set up
Continued,
drilled holes in bucket to mount plow frame, these are 4-1/2" holes.
I took an old plow frame and mocked it up so it would fit on the 45* angle of the LA352 bucket but be pointing perfectly straight. It is welded onto a 1/4" piece of stock. I added angle iron gussets and some 1/4 stock reinforcement plate.
   / My plow set up
Continued,
Now I mounted the frame assembly into the bucket.
This is how I secured the A frame on the plow. There are no hydraulics hooked up to the plow.
The brackets I used were for putting a fifth wheel set up in a truck. I had several extra brackets so I used them. I drilled 2, 1/2" holes in each side of the A frame and mounted the brackets so the plow would not angle left or right. The only thing I did not do yet is drill 1, 1/2" hole on the A frame itself to secure the brackets and make it rigid.
All in all I am into this setup for $300.00 in materials and appx 8 hours of my time. All the welding I did on the bucket was with the bucket off the tractor.
It works VERY well.
Thanks for viewing,
Tim
   / My plow set up
A couple more pictures of the whole setup.
   / My plow set up #6
Hmm... I've been wanting a spread for my set up. What kind of spreader is that on the back? How are you powering it?
j
   / My plow set up
j
It is a Landpride 550? I don't recall the exact spreader model number. I believe it is rated to 750#s of material. It is a shaft power off the rear. I load it up with sand/salt, it works very well as long as the sand/salt is dry. If it gets wet it will not feed down to the spreader.
Tim
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2005 GMC C8500 16FT. Utility Flatbed Truck (A55852)
2005 GMC C8500...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
John Deere 1025R (A53317)
John Deere 1025R...
Honda EM3800SX Portable Gasoline Generator (A55851)
Honda EM3800SX...
