Farmall45b
- Joined
- Sep 18, 2008
- Messages
- 204
- Location
- White Bear Lake, Minnesota
- Tractor
- 2014 Kubota B2650 HSD Cab
I am wondering if anyone has an electrical wiring diagram for a B2320 or could enlighten me some on the rear work lamp circuit. I am thinking of installing a strobe beacon and some work lights on my ROPS. From what I can tell, the circuits supplying the rear work lamp is a 20 amp circuit. What I am thinking of doing is taking the power feed from the rear work lamp circuit and running it through a couple of switches that I will mount in the blank panel on the right hand side of the tractor behind the TPH and 4WD levers. My thinking is that if I mount the switches in the block of plate, I can easily replace the plate and return the tractor to original condition. If I add rear remotes in the future, the tractor won't be brand new and I won't be so concerned about drilling holes elsewhere in the tractor to mount switches. From the switches I can easily run wires in a loom up the side of the ROPS and to the lights. Very simple and clean looking with minimal modification to the tractor. I figure that I will still be under the 20 amps ( or 240 Watts) that the rear work light circuit is rated at with 2 55 watt lights to the front, a rear work light and a strobe beacon. What does everyone think? I am mostly concerned that the circuit is indeed a 20 amp circuit and that I am not overlooking a better location to mount auxiliary switches.
