bx engine[905e]block heater install
   / bx engine[905e]block heater install #1
escavader
western maine
bx-23 ,
Ithought it was a freeze plug type,nope simply unscrew an allen screw.install block heater.Took me longer to get the camera and take pics then to do it:)You need a large socket [1 3/8 ]and large allen wrench[brain cramp cant remember size]
Ihad the tractor apart replacing the lower water hose,[because i had unsuccessfully tried to fit a hose heater in aplace it wouldnt fit:rolleyes:]so while i had it drained i installed this proper kit.7000073274.Takes about 5 minutes after you got your tools out.Kind of glad i didnt have to knock out a freeze plug.
ALAN
oops didnt get a pic of the plug in hanging from it --will do tommorow
Just push it on and tighten nut with fingers your done.
ALAN
   / bx engine[905e]block heater install #3
It's a 17 mm. I know this because I just bought an allen wrench to fit this plug tonight, at Sears. 10 bucks.
Hopefully, I'll get to it over the weekend...
   / bx engine[905e]block heater install #4
$10 ...I might have tried a hex head bolt and vise grips, or a welded-on nut first. ...but, the right tool can make all the difference
   / bx engine[905e]block heater install #5
Certinaly sounds easier and quicker than the freeze plug type I just installed a few weeks ago in my BX. Doesn't help that when I tried to knock the freeze plug out it didn't twist and fell into the block. That took a good 30 minutes to get out dang nabbit. I think my parents should've called me Murphys-law...
   / bx engine[905e]block heater install #6
Isn't that fun when the freeze plug falls inside the block? :mad: Having learned that lesson the hard way, whenever I have to remove a freeze plug I punch a hole in it first, thread in a self-tapping screw and twist a wire around it. Maybe I'm paranoid ;), but I haven't lost one since. I was happy to find my B7800 has the threaded plug, like Alan's.
   / bx engine[905e]block heater install #7
I cracked a beer and did a Hank Hill... 'Yep...'
Stuff like that always happens to me. In one respect it has been good for me. That is how I learned to fix lots of stuff... almost anything I touch seems to break. So I'm somewhat used to it now. I know that when someone says 'installing the block heater should take 30 mins, 45 tops' that I should set aside an afternoon cause without fail, something unexpected will happen. :rolleyes: Just glad I have a heated garage.. :D
ALAN
HERES THAT PIC I PROMISED. The plug end hangs just below the side panel
   / bx engine[905e]block heater install #9
At least the project went smoothly. The screw out plug sure seems a lot easier and leak free than beating on a freeze plug. Mine isn't leaking though but it sure took longer to press in than yours. Glad it worked out for you. Bring on the COLD...
YES,I looked at the guy at the parts counter like he was stupid when he tryed to sell me one with threads:D:DAt least i got good advice on the freeze plug type ,in case i ever do that kind of install.You changed your picture -threw me offbase for a bit:)
ALAN
500BBL WHEELED...
Ford N Series Tractor (A59814)
Ford N Series...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2014 JCB 930 (A53317)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
