Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    May 2005
    Posts
    16
    Hunterdon Cty. NJ
    B7610
    Default BobCat quick attachments
    I am possibly going to purchase a 7800 with the Bobcat quick attach front end
    on the loader. It has the bucket already, but I would like to add a power angle
    snow plow. Has anyone ever used this setup before and was it satisfactory?
    How did you add the power angle hydraulics?
  2. #2
    Join Date
    Apr 2001
    Posts
    777
    MI
    Cub Lawn Tractor
    Default Re: BobCat quick attachments
    Quote Originally Posted by JC3 View Post
    I was told by a local dealer that the Quick Attach took to much of the FEL lifting on the smaller cuts, I was looking at a Kioti CK20s
    KC
    Getting Close to a purchase
  3. #3
    Platinum Member medicshawn's Avatar
    Join Date
    Oct 2007
    Posts
    660
    Central VA
    Kubota L3940 FEL HST
    I don't know what the SS QA weighs but the lifting capacity of the La402 is only like 800Lbs. You might want to make sure the tractor has the universal Skid Steer QA and not just the kubota Auick Attach. I know that make a blade for plowing that doesn't mount to the FEL.
    BX1860 Mowing Machine
    L3940 FEL Sold
    B7800 TLB Sold
    IAFF Local 1568
  4. #4
    Join Date
    May 2008
    Posts
    51
    RI
    kubota B 7800
    Hello
    I have had a 7800 for 4 years with ati quick attach bucket I have added a 7 1/2 foot quick attach fisher power angle with no problems
  5. #5
    New Member
    Join Date
    Oct 2008
    Posts
    22
    Ohio
    2008 Kubota L3240HST
    I have a 3240HST with the SS QA. See enclosed picture for what I purchased off of ebay to remedy your situation. Easily mounted a meyer 7.5' angle plow to this adapter. Run the plow angle hydrualics off of the loader bucket role functions. Works great. Way better than pulling snow with a back blade or driving in reverse for my 1 mile drive. Did that for 8 years.
    Attached Images Attached Images
    L3240HST w/ 724 FEL, R4s.
    RTV 500
    BX1500
    2010 F-250 CC King Ranch
    2004 Harley Road King
  6. #6
    Join Date
    Dec 2007
    Posts
    52
    Wasatch Mountains, Utah
    Kubota B-26
    I have a B-26 with the shid steer QA, and I have started using a 5' curtis plow for this winter, I have been pleased so far, a couple of issues though, I am unable to use the float mode on the plow, as the geometery tends to lift the front tires off the ground, second, is that the plow is a long way out in front, so it has more leverage on pushing the whole machine around in icy conditions. But overall, I am very pleased with the setup, I can remove the plow in 30 seconds and install my forks or bucket, without a big todo As for the added hydraulics, I added the WR Lond 3rd function valve kit, It uses an electric solenoid valve, controlled via a rocker switch mounted to your joystivk handle, it works great. Plan on spending about $700 for the WR Long kit with the quick disconnects and hoses, also If you buy a new power angle plow, you will be in the area of $3k, I bought mine used for $1500 , which I thought was a lot for a used plow, untill I shopped for new ones!
    Attached Thumbnails Attached Thumbnails BobCat quick attachments-100_1841-jpg   BobCat quick attachments-100_1842-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
