Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Dec 2008
    Posts
    21
    Default Glow plug wiring help needed
    Hi Guys,
    I was fortunate to get a good deal on a L35, It only has a couple of issues. The main one is electrical. First problem was a faulty alternator, after reading here I ordered a replacement from Pats small engines.
    I think what caused the Alt to fail is the glow plug controls. Most of the time the glow plug light (and plugs too) stays on all the time. I think this has caused the alt to run overloaded all the time and damaged the alternator.
    Today the glow plugs didn't come on untill I pulled the dash and knocked the relays a bit, now it seems to stay on all the time again.
    From searching here it seems there must be a timer that is supposed to shut the glow pulgs off.
    I am looking for the location of that control. It looks like there is also a Glow plug relay.
    Does anyone have the wiring diagram for these and the relay/timer location?
    I just picked this up this week so I don't have a manual yet-Is there any online manuals?
    Once I get the information I will see just what is wrong and figuire out if I will replace the timer or just rewire it to a momentary switch I will manually use to heat up the glow pulgs thru a relay.
    Thanks
    Jerry
  2. #2
    Platinum Member atgreene's Avatar
    Join Date
    Aug 2007
    Posts
    764
    Sebago, Maine
    2005 TB135 Excavator with Thumb, Quick Attach System, Ripper tooth, 3' Hydrauic Tilt Clean-up Bucket, Skeleton Bucket, 1986 Kubota 4150 with Loader and Quick Attach with Woods Forks, JD B, 1963 IH 504
    Default Re: Glow plug wiring help needed
    You may want to bypass the relay and timer and make your own set-up to manually use the glow plugs only as needed. I have done this a few times. Use a heavy relay/solenoid (the existing one may work, or a new 80-100 amp rated relay) a normally off momentary contact switch and wire it to the solenoid/relay. This allows you to control how much you glow plug and when. I found it works much better than any automated system.
    On edit: switch http://order.waytekwire.com/productdetail/M37/44006
    Solenoid: http://order.waytekwire.com/productdetail/M37/77020
    1986 Kubota 4150 w QA
    2005 Takeuchi 135
    2005 GMC 5500 10' Boss V
    1963 Oshkosh 1967 IH 504
    JD B (Basket case), 2nd JD B, Ford 2n, Gehl 1475 Baler, IH 990 Moco, JD 640 rake
    2009 GMC 3500 6.0
    Local 740 Portland ME
    13 Scottish Highland Beef Cattle, 2 Herefords, 3 Goats, 4 Alpacas, 2 Llama, 40 chickens, 1 Lineback beef critter and lots of maple trees.
  3. #3
    New Member
    Join Date
    Dec 2008
    Posts
    21
    Exactly what I was thinking atgreene,
    I've got an account at Grainger so I can pick up a weather proof switch and relay if I need one.
    What I would like is to have the wiring diagram and timer location so I can rewire without tracing all the wires out behing the dash.
    Jerry
  4. #4
    Veteran Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,203
    MA
    L5450 Cab, L48, L3250, L345DT
    On the Grand L's (similar - maybe identical glow plug control) the starter switch is turned until the glow plug indicator comes on and then later goes off, then the switch is turned further to start.
    The parts list for the L3600 shows a timer T0070-31410 ($72) and a controller 16415-65660 ($62) These two are mounted back-to-back to the glow plug relay 16415-65600 ($26). All three pieces are mounted with 2 bolts inside the body behind the dash panel on the right side. The coolant temperature sender on the engine might be the problem - 16415-83040 ($23).
    Depending on what's defective, a simple glowplug/starter switch without any relays or timers might be a cheaper fix. The older Kubota models used a simple 3-position switch to send power to the glow plugs and/or the starter. The L345 switch is 37150-32200 ($35) plus knob 37150-32210 ($5) - It is wired direct to the glow plugs in one position and in the other it powers the starter circuit too. (On these models the glow plugs also get power whenever the starter runs)
    Kubota parts lists are available by email from Tractorsmart.com
    L5450, L48, L3250, L345, never enough attachments
  5. #5
    New Member
    Join Date
    Dec 2008
    Posts
    21
    Thank You rbargeron,
    I appreciate the info and part #'s.
    Since I don't have any wiring diagrams I can check out the relys etc. and compare to the part #'s you have given.
    It will help a lot.
    Jerry
  6. #6
    Join Date
    Sep 2004
    Posts
    2,171
    Kansas, Butler county, Just east of DooDah
    Kubota L4200 GSTCA
    Jerry...
    This is the layout on Grand L's. I think rbargeron is right, should be the same...
    I reduced the file sizr so they will fit. KennyV.
    Attached Thumbnails Attached Thumbnails Glow plug wiring help needed-dashelectrical.jpg   Glow plug wiring help needed-dashelectrical1.jpg   Glow plug wiring help needed-dashelectrical2.jpg   Glow plug wiring help needed-dashelectrical3.jpg
  7. #7
    New Member
    Join Date
    Dec 2008
    Posts
    21
    KennyV, you the man.
  8. #8
    New Member
    Join Date
    Dec 2008
    Posts
    21
    Just a follow up to say thanks for you guys help. The glow plug controller was faulty. I decided I would rather have a toggle switch to control the glow plugs with rather than a new controller.
    I picked up a 3 position toggle switch (one position is momentary) DPDT plus a weather cover ($17 total) and with the help of KennyV's wiring diagram wired it in a Auto-Off-Hand configuiration.
    Auto- leaves all in original condition
    Off- drops power to the glow plug control
    Hand- (momentary) drops power to the glow plug control and completes
    ground circuit to glow plug relay to operate glow plugs
    Works great and someday when I pick up a new controller I can just change that out and it will work normally if I want.
    Jerry
  9. #9
    Join Date
    Sep 2004
    Posts
    2,171
    Kubota L4200 GSTCA
    Jerry,
    I'm glad to hear you are up and going
    If you can, post a schematic of your change for those that may want to do the same instead of springing the $70 for a controller. Kenny
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
