Page 3 of 20 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 197
  1. #21
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    4,636
    Lancaster County, PA
    Default Re: My quest for "Grand" 3 point performance from my "economy" tractor. The L3400
    Thats correct, but what he was pointing out was the 30 and 40 series grand L's use external 3pt lift cylinders, not the internal rock shaft setups. You'll find the parts and pieces on those are very different. The standard L's share some parts off the old grand 10 series.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Gold Member
    Join Date
    Nov 2007
    Posts
    357
    Kubota L3400 HST-F
    Thanks for joining the discussion Messicks. No hostility directed to you but you just brought forward the essence of the frustration for many of us with Kubota and the L3400 and L2800....
    Quote Originally Posted by MessickFarmEqu View Post
    The standard L's...
    It's always a standard L until you drop 18K and realize your hitch is substandard. Then it's and "ECONOMY L"... check out Kubota web site:
    Kubota Tractor Corporation | L Series Standard L2800 / L3400 / L4400
    Messicks, do you think we can get L3010 hitch smoothness out of our L3400's and L2800's?
  4. #23
    Veteran Member canoetrpr's Avatar
    Join Date
    Aug 2005
    Posts
    2,367
    Ontario, Canada
    Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
    Hmm. I'm beginning to wonder if it isn't the cylinder here that is the missing piece of the puzzle. dkf435 brought up an excellent point.
    I'm certainly no expert in hydraulics maybe the flow is actually too fast on the L2800/L3400 for the 3 PT cylinder they have. I know with my remotes that I had to slow down the flow using 1/4" lines instead of 3/8" lines to get desirable smooth / fine grained control of my top and side link cylinders.
    I'm not suggesting that we should slow down the flow the the 3 pt cylinder - because that would affect the capacity of the 3 pt. I'm just wondering if the cylinder itself is the weak link here and that a different cylinder might help.
    I guess we won't know until you get your valve changed.
    Current: Kubota M7040 cab, hydraulic shuttle, Kubota M20 loader (made by ALO), LandPride RCR1872 rotary cutter, Horst bale spears & forks, Woods HB72 box blade, Kodiak 7' rake, Walco cultivator, chain harrow, Meteor 74" pull style blower
    Traded: Kubota L3400, LA473 HST (300 hrs), and various attachments
  5. #24
    Join Date
    Dec 2006
    Posts
    57
    SE MN
    Kubota L3400
    As you will see from my example, I am no expert on hydraulics either.
    I wonder if it is the design of the valve itself, that it is either full open or completely closed, no gradual closing. I am not sure if this is a legitimate comparison but the example that comes to mind is the water fill control valve on a toilet tank. With the old style valve when it got closer to the full line where it would be completely closed they filled slower and slower until they shut off completely. The newer valves go from full open to completely shut off once they reach the fill line. That seems to be what is happening with our 3ph, completely open to closed, no gradual closing of the valve. If that is the case possibly replacing the valve with one that closes gradually may correct the problem.
  6. #25
    Join Date
    Aug 2005
    Posts
    2,367
    Ontario, Canada
    Rockyridge - if it was the 3pt valve itself then the same valve would not be able to result in smooth performance in the GL 3010 and the L3000. This is why Harvest discounted the theory that it is the valve itself.
  7. #26
    Elite Member
    Parts Supplier
    Join Date
    Feb 2004
    Posts
    4,636
    Quote Originally Posted by Harvest Moon View Post
    You guys are charting new ground with this one. I've never had a customer complain about this, so its not somthing we've really dug into.
    I do think there is merit to what was said about it getting too much flow. That should be an easy thing to tinker with. It won't hurt your capacity since you still have the same PSI. If the parts are the same as the L3010 than I don't see what else it could really be. Thats assuming that the 3010 does not have the same problem.
    I've not seen anything along the lines of a soft close valve. Typicaly cusioning is done with hydraulic accumulators. I'm not an engineer though.
  8. #27
    Join Date
    Aug 2005
    Posts
    2,367
    Ontario, Canada
    Neil - Slightly off topic but related question for you.
    What do you think is a ball park split between % of sales you guys do between the L2800/L3400 and GL3240?
  9. #28
    Elite Member
    Parts Supplier
    Join Date
    Feb 2004
    Posts
    4,636
    4-1 probably. The economey L takes more from the B3030/B7800 than they do from the L40's.
  10. #29
    Gold Member
    Join Date
    Nov 2007
    Posts
    357
    Kubota L3400 HST-F
    If the L3010 has a larger bore, it would fill slower and probably correspond smoother performance... but I wonder, with a higher relief pressure, if the bore is larger and if it is, how much larger could it be?
    The L3010 uses the same rod so the stroke would probably be the same.
    I'm still thinking there's got to be a reason for the extra spring in the LSV, mine lowers smooth as silk at any speed with out the extra spring.
    It's very likely that this spring does something but maybe not as much as I hope. If canoetrpr is right, maybe we'll only see a 10% improvement.
    One thing that isn't in debate and that is the original jerky PCV is much worse than the L3010 PCV. Your all welcome to interpret for yourselves and invited to comment but to me it looks like the difference really boils down to two springs. If that's the case, then what else can we conclude but that the LSV with the spring will help too? So long as it fits?
  11. #30
    Join Date
    Aug 2005
    Posts
    2,367
    Ontario, Canada
    Wow! I didn't realize that the Grand L sales were so much fewer than the B series.
    Makes sense that the Economy L really take from the B7800/B3030. I was looking at the B7800 myself when I realized that the L3400 made much more sense for me.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
