Results 1 to 6 of 6
  1. #1
    Join Date
    Dec 2008
    Posts
    1,278
    Up-State New York
    Grand L 3540 HST-3, R4's
    Default BX2750 Front Snowblower
    Hello All,
    I have a question about the BX2750 front mounted snowblower that is mounted to the front of my BX23-TBL. This is the first year that I have used this BX2750. First, this snowblower works just Great! It blows the snow soooo well, no issue with that, but--- after reading some posts on here. I remember some users saying something about using the float for the snowblower. Where is it? I do use the float when I have my loader on as the ident for float is straight up. But when snowblower is hooked up, only the two center hyd lines are used and for up you move controler to left, for down move controler to right. They control the up and down only, Soooooo my question is where is the float position for the snowblower? Do I have my hyd lines hooked up in the wrong position? Thanks
    Devil Dog
  2. #2
    Platinum Member SeymourBota's Avatar
    Join Date
    Aug 2004
    Posts
    718
    Central Vermont
    Kubota B2410, BX2200
    Default Re: BX2750 Front Snowblower
    You're hooked up wrong. You should be using the opposite two lines and the controller should operate similar to the loader- down to raise and up to lower/float.
    Colors won't match.
    It's red and blue on the blower lines but white and yellow on the controller side.
    Peter
  3. #3
    Join Date
    Dec 2008
    Posts
    1,278
    Up-State New York
    Peter,
    Thank you for the correct color for hook-up, I will go out to barn and hook-up the color combination that you suggested and try the lift on blower. I'll post my results.
    Devil Dog
  4. #4
    Join Date
    Dec 2008
    Posts
    1,278
    Up-State New York
    Pete,
    Your the man, Thank You once again. I did what you told me to and guess what? snowblower works just like my loader. I don't understand how I missed that hook-up as i have all the manuals for every piece of equiptment that I own, duh----. I guess just in time as Tues. night we're suspose to recieve 6" to 12" of that white stuff they snow in the Great Northeast. DevilDog
  5. #5
    Silver Member bitseeker's Avatar
    Join Date
    Jan 2004
    Posts
    100
    Mount Shasta, California
    GL5240
    Here is an eBay item for float on gravel and rock. Snowblower Caster Wheel Assembly - Excellent Condition - eBay (item 150323601429 end time Feb-06-09 11:17:39 PST)
    Attached Thumbnails Attached Thumbnails BX2750 Front Snowblower-1019e-float-casters-.jpg
  6. #6
    Join Date
    Apr 2007
    Posts
    505
    Northern Lower Michigan
    Kubota B3030HSDC
    Just purchased this unit on e-bay. Thanks bitseeker for posting this. Never thought about this idea,but seems worth a try for us.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
