dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,178
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
One final question. I noticed the tractor's piston rod at the backhoe bucket has a slight curvature to it along a the front to rear axis. There are no leaks and the bucket works fine. There also does not appear to be any dings or marks on the piston indicating an impact. Are these piston rods designed that way by chance?
Not just "no", but he** no!
You have to straighten the rod before you buckle it. If it is only slightly
bent, you can straighten it to near perfect using a press. It requires
disassembly of the cylinder. I have successfully straightend several
rods with my HF 20T press. If you do not have that setup, take it to
a machine shop.
As for the 3-pt hitch, my B21's parts were all missing, too. I suspect that
most owners do not store the arms in the provided brackets. I, too, think
you will be fine with aftermarket arms, lift links, and stay chains of the
correct size. Aftermarket toplinks are often superior to the OEM Kub units.
