Log splitter connections
   / Log splitter connections #11
Thanks KennyD and FirefighterKubota. The only question I have left is does the FEL and the 3PH still operate with the splitter in series?
Also, I think I'm going to go with the Split Fire 3203 instead of the Powerhorse. Splitfire quoted me $1000+freight which given our dollar and the shipping from the US, it puts it pretty close in price and gives me 24" capacity and what looks like a stronger unit (it weighs twice as much).
Kory make sure you check the size of the cylinder (bore) for that unit. Anything larger than 3" will be very slow with your tractor.. Also Does that split both directions? I think so but don't rememeber. Bi directional splitting helps speed up splitting with slower hydraulic systems.
   / Log splitter connections #12
Kory here are the pics you requested.
#1 is the PB port on the loader valve, the original line was removed dn this now runs to the rear of the tractor with quick connects
#2 are the quick connects on the tractor
#3 are the QC on the splitter
#4 is the return line from the Rear QC to the hydraulic block, From here the hydraulics then feed the 3 pt hitch.
#5 it the 3' line that originally went from pic #1 to #4.
Very simple.
But as Kenny pointed out..the rear QC need to be coupled together or to the splitter to make a continuos loop at all times. (make sure your splitter valve is n OPEN Center, Should come fromthe factory that way)
As long as the QC are connected or QC to the splitter all hydraulic functions operate as usual . Also you will want to shut down the tractor, when makeing connections as the pump is always circulating fluid...
Good luck..
FFK, thanks for the pics. I'll respond to your PM when I get a chance. The Split-Fire 3203 has a 3.5" x 24" cylinder and does split both ways. According to Matt at Split-fire, my BX will run this in 8-9 seconds. If I can keep up, that's two splits every 20 seconds or so. Pretty quick.
http://www.split-fire.com/splitter_3p_3203.html
   / Log splitter connections #14
Split-Fire Sales Inc. :: 3203 Woodsplitter :: Quality Built. High Performance. Split-Fire - Your Best Choice
I did look at that unit...The powerhorse was substainally less money, almost $300 , my wood stoves don't take anything larger than 18" so I didn't need the length, and with the length there is alot more splitter sticking out the rear of the tractor... :eek:
If I had a larger stove I might have gotten the split-fire.
Good luck
OK, just when I thought I had this all figured out, I actually got a chance to look at my BX2660 and I'm lost all over again. The BX2660 has an integrated FEL control so all of the plumbing is well hidden and tightly packaged. The result is that there is no clear indication of which line is the power beyond circuit.
I believe that it will be far easier to extend the existing line at the rear of the tractor than trying to replace the line all the way from the front. What I need to know now from the vast knowledge of TBN is which connection is the PB? I may be able to figure it out with some exploratory surgery, but I'd rather go in with some education.
Also, if anyone can tell me if this will interfere with the future addition of rear remotes, that would be a bonus.
   / Log splitter connections #16
On the valve assembly there should be a PB stamped into the valve...Also this line will run from the valve assembly to the hydraulic block. On the block there is a line running out into the valve and a second one returning.. Your block may look different but here is a reference picture.
Pictures tell alot. I'm not familier with your lay out so take some pics and post them of your "rear" line
Really need to see your set up.., Pictures !!!
Finally got pictures. Here's the view from the right side and rear. I assume this is the right spot since this is where the lines for the FEL originate. Let me know if you need to see more.
   / Log splitter connections #18
Right, are there any markings on your FEL valve where the lines go in? Look for PB (if not ask your dealer which one is the PB Power beyond)
From your picture it SHOULD be the line on the left when looking at the side. (unless kubota ran the system backwards) Thats the line you want to remove entirely and run a new line from the fel to a set of quick connects at the rear, and then back to the hydraulic block.
keep the QC connected when operating the tractor, and connected to the slpitter when it is mounted.
You need to SHUT the tractor off when making connections as the hydraulics are always flowing when the tractor is running..
Let me know if you have any questions..
OK guys, I'm pretty confident that I've got this. A little research and exploratory surgery netted the following pictures. One is from the parts book, and the other from my FEL valve. The line I need to tap into is the one marked BY on the valve and listed as PB on the diagram, right? This would make it the forward of the pair of lines at the rear as in the third picture, according to the parts diagram and from tracing it back from the FEL valve.
So, what I intend to do is to extend the PB line at the rear point just before it goes into the elbow. Then I'll rotate the elbow rearward and extend a line from there. The two new lines will be coupled together until I want to connect the splitter, then I will uncouple and insert the splitter. If this all sounds good, let me know.
My only outright question is does it matter which side connects to what line on the splitter? My thoughts are that it doesn't since the PB circuit is just providing flow and the splitter valve directs it. It shouldn't matter which quick connects are male or female, and I shouldn't have to mark them, right?
   / Log splitter connections #20
You are correct on most accounts, except your spitter valve ports will be labeled IN and OUT . if you reveresed the flow I don't think it will harm anything but it WAS designed with a flow in a particular direction...so on your initial installation, make sure the PB line goes to the IN side. Once you've done it once with the quick connects, it will line up every other time.
Good Luck.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
2022 Caterpillar 420 Extendahoe Loader Backhoe (A49461)
2022 Caterpillar...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
Miller Bobcat 225G AC/DC Welder Generator Set (A49461)
Miller Bobcat 225G...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
