Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Mar 2009
    Posts
    5
    Default 7500 question bad sound and tiller question
    hey guys I got a 7500 year 02 I bought it with 110 hrs and it is now almost 200. The thing is when i am in high gear wide open some times I hear a wyning noise from i think the rear end . if you come to a stop and then start agian its not there untill you go a little ways . it also happens when the tractor is hot or has ran a while . any thoughts. also i got a steal on a 5 ft tiller king cutter is it to big for my tractor. and if it is to you think if i take a row of tines off that it would hurt the tiller . I ran a 4ft just fine last year .
  2. #2
    Gold Member dillo99's Avatar
    Join Date
    Aug 2005
    Posts
    376
    Upstate NY
    Kubota B7500
    Default Re: 7500 question bad sound and tiller question
    Welcome to TBN.
    When you say you are running "wide open" I assume you mean the throttle is pulled so it is all the way at the top? What kind of RPM's do you see then? I honestly don't know if I have ever run my tractor pegged on the throttle. Never had a need for more than 540 rpm's.
    The noise sounds like it is coming from inside the rear end? Is this with the PTO engaged? I assume fluids are okay? Since the tractor is relatively new to you, do you know what kind of Tran fluid is in there? Is it super UDT?
    Regarding the tiller - I think you will be okay depending on your soil.
    Mike
    B7500, Loader: LA302, Backhoe: B4675, 3ph splitter, 3ph dump hauler, 5' Bush Hog, 5' rear blade, Chipper, 1 Wife, 3 Daughters and 2 Dogs (oh yeah...cat too but who counts them)
  3. #3
    New Member
    Join Date
    Mar 2009
    Posts
    5
    no the pto was not engagd just running down the drive and road . the fluids are up to the proper level on my dip stick but does that matter when you are checking it if the 3point is up or down. the fluids are the super new filter and fluids
  4. #4
    Super Member
    Join Date
    Apr 2000
    Posts
    5,673
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    If this is not a new sound it could just be the way HST sounds in high gear. At least my HST has a whine when in high, which isn't very often. In high gear there isn't much power on any type of grade and it seems the loudest then. Watch your RPM's and see if they are dropping when you think the noise is the worst.
    MarkV
  5. #5
    Join Date
    May 2008
    Posts
    106
    Cullman, AL
    Kubota BX2350
    My BX2350 has a whine when running down the road in high at near full throttle. My dad has a L3400 that does the same thing. I think this is just normal for the HST tractors. Even the old gear drive tractors would whine when running WOT pulling a plow.
    Kubota BX2350
    54" MMM
  6. #6
    Veteran Member theboman's Avatar
    Join Date
    Jun 2001
    Posts
    1,578
    Grayson, KY
    Kubota B7500 HST
    They they sound like women from time to time, well at least my wife!
    I think it's normal, I hear mine do that too.
    Check your parking brake too if you notice a loss of power.... We've all done that a few times.
    Bo McCarty
    THE BO-MAN, er BO-DADDY
  7. #7
    New Member
    Join Date
    Mar 2009
    Posts
    5
    my 7500 is not hydro its the gear type if that helps guys
  8. #8
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    Code:
    Try it and see what happens. Then adjust as necessary.
    I had removed two outside rows of tines on my tiller so the Little kubota B7100 could handle the soil conditions. After breaking the sod I was able to put the tines back on.
    It may all depend on soil conditions. The gear tractor may not be as flexible for tilling at slow speeds as a hydro.
    The whine may come from gears?
    The way gear teeth are angled when manufactured may effect the amount noise they make??
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
