Results 1 to 8 of 8
04-15-2009, 08:10 AM #1
Some people grow veggies, I grow ROCKS
Well I finally got started on a job I had been meaning to do for about 3 years. That job Pulling as many rocks out of my field as my BX could do. In about 3 hours I pulled about 120 medium to large size rocks out of a 150 x 75 foot section of my field. Only hit 2 that I have not been able to pull out with the backhoe. one that is loose in the hole but the hoe cant pick it up just rolls it around. But I did hit plenty of rocks that the FEL couldn't pick up had to push them to the rock pile. Even as an owner I sometimes under estimate what a BX24 can do. I figure that if I cant move it (it being stump, rock ect ect) I can just leave it there till I have enough to rent a bigger machine.
Some pics:
Picasa Web Albums - Matt - Tractor
Picasa Web Albums - Matt - TractorMatt
BX 24
LA240 FEL, BT601 Backhoe, 54'' MMM, Patu DC 40 Chipper, 5ft LandScape Rake, FEL Snow Plow, ATI FEL Quick Attach, TracVac with QA mower boot, WorkSaver Post Hole Digger, 50$ 4ft Grader Blade
04-15-2009, 08:13 AM #2Gold Member
- Join Date
- Apr 2009
- Posts
- 296
- Location
- Mason MI.
- Tractor
- B2920
Re: Some people grow veggies, I grow ROCKS
WOW!
Those are some BIG rocks..
04-15-2009, 08:24 AM #3
HUH! You sure are growing rocks!
What I don't understand is why are you digging them up if you have no use for them ? What I would do is use the bota and dig 6 foot hole right next to the rocks and push em in. This would solve the biggest rocks movement problem and gets them out of your way. Since the BX24 can dig 4 ft easy in the ground, it can go 6 ft when needed.
If you have no plans for those rocks and want to show off your hard work
then make a japanese style garden with them.
04-15-2009, 08:29 AM #4
You know what they say............ the most bountiful crop in New England, ROCKS !
I'll let you in on a secret I learned back (waaaaaaay back) when I was a teenager digging pools for a pool company. Dig a big hole next to the rocks that are too big to move. Leave a bit of a downhill path into the hole, then push or pull the rock into the hole and bury it.
Another alternative would be to drill holes into the big rocks with a masonry drill. Pickup some Dexpan Non Explosive Blasting, Controlled Blasting No Explosive, Non Explosive Demolition and use it to make smaller rocks........ which you can then move.
Good luck !
04-15-2009, 08:44 AM #5
Plans are for the rocks is A) to move them so I can grade out the field in that area for a riding arena / 2nd paddock for my wife's horses. B) going to use the rocks to build a retaining wall of sorts and border my driveway.
I have tried to dig bigger holes and rolled a few big rocks in there usually that gets me more smaller rocks to deal with and is usually a pain since the huge crop of rocks.
Ductape : Ive done the hammer drill routine more then once to drill and then crack with a sledge, I will have to check out that demolition stuffMatt
BX 24
04-15-2009, 09:02 AM #6Gold Member
- Join Date
- Mar 2009
- Posts
- 431
- Location
- Lampasas, Tx
- Tractor
- Kubota L2800
You might want to check and see if there is a market for the rocks.. in the past few years the trend if for huge rocks to be used by landscapers... People go nuts over huge rocks ....
The Dougster in the Great Republic of Texas
04-15-2009, 09:34 AM #7Gold Member
- Join Date
- Jun 2008
- Posts
- 416
- Location
- North East New York
- Tractor
- Kubota B2620
I too grow plenty of rocks here on my spread. I love them though and use them throught the landscape, walls, landscape borders, etc... See some of my collection below, this is about 1/3 of what I have dug out so far.
Kubota 2620, Loaded R4's, FEL, 4' Bush Hog box blade, 5' Bush Hog landscape rake. Toro Timecutter Z 5060 ZTR 50"deck
04-15-2009, 06:00 PM #8
