Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Member
    Join Date
    Apr 2009
    Posts
    48
    Default Looking for a Backhoe
    I have a 2007 3030 with a Cab, I was told that kubota does not make a backhoe for a 3030 with a Cab. I was thinking if I got an old backhoe I could modify it to the 3 Pt and have it out far enough that it would work with the cab. Does anyone have any ideas for this project.
  2. #2
    Elite Member
    Join Date
    Sep 2004
    Posts
    2,568
    Kansas, Butler county, Just east of DooDah
    Kubota L4200 GSTCA
    Default Re: Looking for a Backhoe
    Go with Woods and a sub-frame... KennyV.
  3. #3
    Join Date
    Oct 2005
    Posts
    1,537
    Cincinnati, OH
    Kubota B3030
    Quote Originally Posted by KennyV View Post
    100% dead on!!
    Kubota B3030 with 40 amp alternator kit; LA403 FEL; 60 inch backblade; sub-soiler; ballast box; EzMover hitch; Payne clamp-on bucket forks; a HD set of smaller discs and a 60" landscape rake with dolly wheels
    Hobart HH210 Mig welder
  4. #4
    Join Date
    Jan 2008
    Posts
    53
    South Eastern Ontario
    2008 L5240HSTCC, 2007 B3030HSDC, 2008 F3680, 2008 GR2100
    Hi Fritzy.
    I'm in the same boat...except I'm just dreaming at this point.
    Based on my "extensive" research on this site, and in speaking to dealers the Woods "x" series is the only BH that offers a 4 point sub frame for the 3030 with cab.
    My dealer told me it was possible to make the BH75 work, but he didn't recommend it. I didn't get the details.
    I sent an enquiry to Wallenstein, as they are Canadian, make good stuff and have a good looking new backhoe, but go no response on the 3030 with cab question.
    The biggest question with the Woods unit is BH70X or BH80X. You'll find lots of opinions on that if you do a search. You’ll also see that it is suggested that you get the wheel spacers, as Turfs will rub in the mounting brackets.
    Best of luck, and have fun.
    JL
  5. #5
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,856
    Central New Hampshire
    Kubota B3030HSDC
    This is what you need.
    Attached Thumbnails Attached Thumbnails Looking for a Backhoe-bh-80x-004-jpg   Looking for a Backhoe-bh-80x-006-jpg
  6. #6
    Join Date
    May 2008
    Posts
    51
    RI
    kubota B 7800
    Go with a woods bh70x been doing my home work with woods I have a B 7800
  7. #7
    Platinum Member peterc38's Avatar
    Join Date
    Aug 2006
    Posts
    712
    Maine
    Quote Originally Posted by Ductape View Post
    Great looking set up Ductape
    Kubota L4060 Cab HST
    Landpride RB1684 rear blade w/ hydraulic angle
    John Deere X500
    Husqvarna 562XP
    Husqvarna 371XP
    Husqvarna 346XP
    6 x 10 Dump Trailer
    22 ton Speeco Logsplitter
    2 Great Danes
    Vive l'acadie!
  8. #8
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,276
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Quote Originally Posted by AJL View Post
    <snip>
    The biggest question with the Woods unit is BH70X or BH80X. You'll find lots of opinions on that if you do a search. You値l also see that it is suggested that you get the wheel spacers, as Turfs will rub in the mounting brackets.<snip>
    JL
    Looking at getting a BH70X for my B7610 - can you provide more info on the "rub"?
    I tried a search and did not find anything yet.
  9. #9
    Member
    Join Date
    Apr 2009
    Posts
    48
    Dutetape, very nice unit, that is what I want, what kind of $? I see you have the turf tires, do you have any problem in the show? I am in Ont. Canada and we do alot of snow blowing.
  10. #10
    Join Date
    Feb 2006
    Posts
    4,856
    Kubota B3030HSDC
    Quote Originally Posted by newbury View Post
    The backhoe mounting pins (technically bolts) slightly rubbed the insides of my turf tires. It would not have been an issue at all if I had R4s, since the turfs are a bit wider. As a temporary solution, I shortened them slightly with my bench grinder...... but it was still awful close. I didn't want a little side wall flex to ruin my day when driving on a side hill, so I installed kubota's wheel spacer kit. I'm unaware of there being an issue with any other model. I actually wanted the wheel spacers for added stability anyway..... it just made me buy them sooner. They were $150 +/-.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
