k8ny
Well, well. Been quite a while since I've been on this forum.
Just had my BX 2200 power steering hose fail for the first time. Was not aware that this was a problem until I noticed hydraulic fluid leaking down from the engine compartment (actually it was the hoses passing near the compartment).
After a long examination I located the leak source (just as the hose is bending outside the battery compartment).
Spoke to the first Kubota dealer- he said it was a common problem on most BX 2200's. He explained that the quality of the hose was not the best and that excess heat and pressure caused by long max steering input as well as the hydraulic control lever not returning to neutral after raising or lowering deck contributes to the failure. At any rate, whatever the cause, mine is leaking fairly heavily.
After doing a search here on the forum, I discovered an interesting fact some member posted. In the BX 2200 Operator's Manual, under the Maintenance section, it states that the Power Steering hoses need to be replaced every 2 years. Interesting. I am not a hydraulic expert but this sounds way premature for replacing hoses.
Anyway, the dealer tells me this is a time consuming job as ROPS, tank and other assemblies need to be removed in order to replace hoses.
My first dealer quoted $460.00 including 6 hours labor. The second dealer quoted $340.00 including labor.
BTW mine is a 2001 BX with 520 hours.
Would be interested if members with newer model BX's have the same Maintenance requirements in their Operator's Manual.
Thanks - Bob
Thanks - Bob
