Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,900
- Tractor
- Kubota BX25
I raised the pressure on my BX25 to 2000 PSI; what a difference, especially in the FEL operation. Factory spec is 1778-1849 PSI. Kubota only uses one relief valve for all the SCUTs. Pressure is changed by adding or subtracting shims under the spring. Each 1 mm added changes pressure 39 PSI. WSM shows how to do all that. If you follow the hydraulic system in the WSM you will see it only affects the attachments not the transmission as it has its own pressure regulation. Increasing the pressure will make the relief valve a little noisier for awhile then it dies out. I made a gauge unit using a forged steel 3/8 IPT tee with a 1/4 branch. male and female QCs on each end and gauge in the branch. Kubota uses standard Parker QCs available at most HYD shops. Surplus Center does not sell them. Connect it temporarily in the power line for the BH as that is the first outlet in the PB string..
JJ there is some more info for your vast data base.
