Rebel
Does anyone know if there is a 3 point Down Pressure Kit available for Kubota L-Series tractors?
y
Go to the Land Pride website:
Land Pride
Under "Products", select Post Hole Diggers.
Each size PHD has a page and on the left of each page is a menu. If you click on "Specifications" or on "Features" PDF documents will download and you will be able to see some information about their downpressure units. I am fairly sure that something there will fit your tractor. I couldn't find much more specific about their downpressure units; perhaps this is because they are considered parts or accessories. Their site will give a directory to dealers so that you can locate and find a dealer in your area. Good Luck.
I doubt it.
Usually adding weight to the implement is the best solution. If you "push" the implement down it will take weight off the rear tires reducing traction-so it's kind of counter-productive to add downpressure.
I was thinking of adding weight to my BOX SCRAPER. I,too have the Kubota "L" and no down force. Wacha think of welding 1/2" steel plates on each end and a long plate across the back? OR....the barbell with end clamps across the upper hitch frame (but that would raise the CG). I was kinda worried that although light the scraper does jump over rocks....but if heavier am I going to break something??Suggestions? :confused2:
Thanks
The problem with adding weight to a light weight box blade is that you now have the digging force of a heavy box blade, but the light weight box is just that, light weight. The metal and the construction of a light weight box blade used as if it were a heavy duty box blade will fail at sometime. There just is not enough material there to be able to hold up to heavy duty use and or abuse.
Just my :2cents:, your mileage may vary.
IDEA to ponder;
How about running a steel cable from a post hole digger, possibly attached between the 3 point and the PH boom, run it over, er under a rear and front pully under the tractor and then attach to the bottom (or any handy (safe) FEL point!
Lifting the FEL would pull down the post hole digger. Should work!
