Results 1 to 10 of 10
  1. #1
    Gold Member samofsweden's Avatar
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Default Important! Engine Failure for BX24 and BX2350 owners?
    Hi. I just did my 300hours service. My BX24 lives a hard life but well maintanied live. Please check your BX,s so you dont have this potential breakage as I find out. I have to order a new waterhose on monday.
    /Sam
    Attached Thumbnails Attached Thumbnails Important! Engine Failure for BX24 and BX2350 owners?-rimg0074-jpg   Important! Engine Failure for BX24 and BX2350 owners?-rimg0076-jpg
  2. #2
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    2,457
    Conn. & Florida
    Kubota BX25
    Default Re: Important! Engine Failure for BX24 and BX2350 owners?
    Thanks for the heads up. Will be doing my 50 service soon and will look for any wear on the coolant hose. Even with a new hose, how are you going to make sure it doesn't rub on the fan belt?
    Chris
  3. #3
    Super Star Member
    Join Date
    Dec 2003
    Posts
    12,491
    NC
    Kubota Grand L3830
    How about frabicating a brace out of 3/4 inch flat stock drill a hole in the end for the bottom alternator holding bolt and then twisting the flat stock in a vise to hold the hose back and away from the belt as is being done in photo number one by the posters hand and finger.
  4. #4
    Gold Member
    Join Date
    Sep 2008
    Posts
    356
    Central Maine
    Kubota BX24 TLB
    You might try one of those bling-bling braided hose covers over the water hose.
  5. #5
    Elite Member Skyco's Avatar
    Join Date
    Jul 2007
    Posts
    2,718
    SC/NC
    I agree with a bracket to hold clearance, since both the hose and the belt need to be protected from rubbing, don't want to lose either one
  6. #6
    Silver Member Tractorbeam's Avatar
    Join Date
    Apr 2008
    Posts
    127
    Winchester
    New Holland T2320 and Kubota ZD326 ZT
    The engineer who designed this missed his calling. He should have been a weather man instead.
  7. #7
    Silver Member jesseb3@att.net's Avatar
    Join Date
    Jun 2006
    Posts
    225
    South Central PA
    Kubota BX2350, John Deere X530
    Sam,
    The same thing happened to me. I let the dealer who I bought my BX2350from perform the first service, as I had some recall issues (broken operator's deck.)
    Anyway, when I did the next service, I noticed that the oil filter that I was given by another dealer was much smaller than what was on it. From what I could tell, the original dealer used a filter that's listed as "compatible", but it pushed the hose into the belt.
    If you get the smaller one (supposedly the one that it's meant for), the hose stays well clear of the belt. At least that's what happened to my BX2350.
    Jesse
    BX2350 - FEL, 48" Box blade, Markham toothbar, ROPS mounted lights, BXpanded bucket hooks, 48" Howse brush cutter
  8. #8
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Quote Originally Posted by CHDinCT View Post
    Thats why we all stay here, to give and take. I really hope no one has ruined his or hereď˝´s engine. I took a BIG nylon-strap to hold back the hose.
    /Sam
  9. #9
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Quote Originally Posted by Gator6x4 View Post
    Good idea! At the moment Im using a Big nylonstrap.
    /Sam
  10. #10
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Quote Originally Posted by jesseb3@att.net View Post
    Sam,
    Jesse
    Hi Jesse. So you where lucky aswell! Im using orginal oilfilter and a BIG Nylonstrap as mentioned above, I think that will do it. Using a smaller oilfilter doesnt sound (at least for me) as a good idea, but I can see the benefit doing so. I think that the problem was created from a to "untensioned" fanbelt. In conbined with to close hose together with engine run on idle, it create more vibrations.
    I bought my BX in US then I shipped it to Sweden...so I cant to any recall issues, but Im very very impressed of my BX24. I use it in my landscaping business.
    Good luck!
    /Sam
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
